This solved my problem. Now it works right also with sef404 enabled.Matias wrote: Kunena does not list users that have not finished the registration process (most of them are created by bots for spamming). Those users are generally not shown in any Joomla extension.
Having empty pages sounds like a bug, though..
Try to change components/com_kunena/template/default/plugin/userlist/userlist.php lines 55-59 into this:
Code:$query = "SELECT COUNT(*) FROM #__users AS u INNER JOIN #__fb_users AS fu ON u.id=fu.userid WHERE block=0"; if ($search != "") { $query .= " AND (u.name LIKE '%$search%' OR u.username LIKE '%$search%')"; }
thank you very very much
Cerberus wrote: issue:
maps are hiding any text and the quick reply box is half hidden by map too.
idea:
Maybe a max size on them ? or a thumb version (small version ) in the message then on click it opens in the java popup as a bigger version ?
This is a browser issue we need to fix. Has nothing to do with the size. It works in Safari and Chrome but IE and FF currently have issues.
- Khodzhamberdiev
Khodzhamberdiev wrote: 1
Hi!
Welcome to the Kunena!
Please leverage out Playground for any testing you would like to do onsite.
You can find the Playground in the main menu or directly here: www.kunena.com/playground
I will move this into the playground area as well.
Hope this helps!
