Question help needed for CB 1.2 and kunena Integration
17 years 8 months ago #9801 by Amby
Hi All ,
I have a joomla 1.5.9 site and i have installed CB 1.2 and kunena latest version .
I have been trying to integrate the two since the last three days but i am not able to and i badly need help !!
I found some documentation and follwed these steps :
Step by Step instructions to integrate Community Builder with Kunena (formerly Fireboard / Simpleboard / Joomlaboard) Forums:-
* Install CB 1.2 stable
* Publish the System-Legacy plugin (Extensions->Plugin Manager)
* Install Kunena 1.0.8
* Publish the plugin (no need to download or install anythign it's part of CB ) Admin-> Components -> Community Builder -> Plugins -> Fireboard Forum
* Publish the Forum tab in the CB user profile - Components -> Community Builder -> Tab Management -> Forum
* Edit the two plugin files cb.simpleboardtab.php and cb.simpleboardtab.xml. Simply search for "fireboard" or "Fireboard" and replace with "kunena" or "Kunena". Path is Joomla / components / com_comprofiler / plugin / user / plug_cbsimpleboardtab
* Edit cb.simpleboardtab.php to fix the formatting problem on the CB Forum tab which is caused by the fact that the </div> tag following the <div class="sectiontableheader"> tags incorrectly appears after the following <table></table> sections rather than before them. To make this easier I've attached a sample file which has both the fireboard / kunena substitution and the necessary php changes to fix the formatting issue. Please note that although this works for me on my site, and renders correctly in both IE7 and Firefox 3, this is the first PHP file I've ever editted so I cannot warrant that what I've done is entirely correct and bug free. All changes are commented with "// TW change". Download file and rename to cb.simpleboardtab.php. Then save into the Joomla / components / com_comprofiler / plugin / user / plug_cbsimpleboardtab folder.
* Configure Kunena (Components -> Kunena Forum -> Kunena configuration). Go down to the Integration sections near the bottom and change Avatar Integration and Profile Settings to "Community Builder"
I think the profiles have been integrated . However When i click on a user profile and go to Forums tab :
I get a message "The forum component is not installed. Please contact your site administrator."
Also In user stats :
Forum Ranking: ---
are not updated !
Has anyone faced a similar problem before ?? Has anybody successfully integrated Kunena with CB 1.2 . If yes , please help . I am sure this answer will help many like me who are struggling with the integreation .
Regards ,
Ambar .
17 years 8 months ago - 17 years 8 months ago #9817 by sozzled
This is my favourite discussion topic! :woohoo:
You're not alone, Amby!
The symptoms of your problem
were rather unhelpfully addressed (over one month ago) at Joomlapolis ( Kunena Integration with CB ). When asked for an update on the status of the work that's being done to address these problems ( CB & Kunena Integration Status ) the result was again quite unhelpful. It's my conclusion that you should anticipate a solution in the next release of Community Builder within the next 3 months.
When you say that you're trying to integrate Community Builder with Kunena, this is a very broad subject.
The forum tab: I see you've referred to the famous Tony Woodhouse Kunena Integration with CB - Step by step guide . That approach looks like it should work although I haven't tried it. I don't remember what order I installed Kunena or CB, but it probably doesn't matter. Instead, I used the CB tab for Kunena that I discovered in this forum. With a bit of fiddling, this method worked for me - I can provide you with a demonstration site, if you're interested.
User profiling: The Tony Woodhouse solution suggests that you use "Community Builder" for Avatar Integration and Profile Settings when configuring Kunena. For various reasons you should exercise these choices carefully. In our discussion Signature, ordering and viewtype migration script for CB you will observe that there are difficulties and overheads in synchronising some of the CB data with Kunena. In fact, it could be said that using Community Builder user profile information may be quite undesirable!
I attempted to summarise some of the difficulties, pitfalls and workarounds between the two profiling systems for users of Kunena: CB vs Kunena profiles .
I hope this information helps you. As I said earlier, you're not alone, there are ways to fix your problem but you may have to wait a while before Community Builder catches up.
Last edit: 17 years 8 months ago by sozzled.
17 years 8 months ago - 17 years 8 months ago #9833 by sozzled
Please ignore my earlier recommendation to use the CB tab for Kunena that I discovered in this forum. It causes other problems! I will be posting details in that discussion topic. I recommend the "Tony Woodhouse" solution!
17 years 8 months ago #9859 by Amby
Hey ,
Thanks a zillion for helping me out . I am new to this and was struggling a lot .
It feels good that somebdy is helping me out :)
I will try what you have told me and yes your suggestions made sense to me .
I look forward to come back to this forum again .
Thanks again for your advice ,
Ambar .
17 years 8 months ago #9898 by Pumuckl
I think this is solved now, you can use all Boards e.g. Kunena, Fireboard, Simpleboard and Joomlaboard.
I've added a 4th entry for Kunena.
Attached the two files to change in CB 1.2
See also:
www.joomlapolis.com/component/option,com...w/id,93051/catid,77/
File Attachment:
File Name: plug_cbsim...c855.zip
File Size:10.34 KB
17 years 8 months ago #9904 by itgl72
I've tried a bunch of fixes. I have it working but am concerned about going live just yet with future updates coming (I HOPE SOON!) between Kunena and CB.
THE ONLY thing I do not have working is the MESSAGE ORDERING. That does not work.
