Question Problem after installation
16 years 5 days ago #71328 by panosbouras
Hi all,
After installing the latest Kunena, I get the following error in Jomsocial (which I am running the latest version) running the latest version of Joomla also. The message I get is No valid database connection Table 'web126-a-joo-32.jos_fb_users' doesn't exist SQL=SELECT a.*, b.* FROM jos_fb_users as a LEFT JOIN jos_users AS b on b.id=a.userid WHERE a.userid=215. I get this message though ONLY on the joomsocial profil page. Any suggestions???
16 years 5 days ago #71343 by xillibit
Can-you put here a Kunena report configuration setting ?
16 years 5 days ago #71353 by panosbouras
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 24M | Max file upload: 10M
Joomla default template details : ooopa_fakebook | author: Ooopa! Templates Jomsocial | version: 3.0 | creationdate: 2010-10-11
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.11) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Enabled (Version : 1.6.0-RC1) | My Kunena Forum Posts: Disabled or not installed
16 years 4 days ago #71386 by xillibit
I think you are a jomsocial plugin which isn't comaptible with k1.6.
16 years 4 days ago #71456 by panosbouras
any remedy to it? Can I unistall the plugin would it work?
