Question Component not found when I vote in a Kunena Poll
15 years 10 months ago #69252 by Zafit0
When I vote in a a Kunena poll I get 404 Error - Component not found... How I can fix that?
Link: www.megaclubs.es/?catid=13&do=vote&func=polls
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 100M | Max file upload: 64M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.10) | UddeIm: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Disabled or not installed
15 years 10 months ago #69266 by fxstein
The URL above is not a valid Kunena URL. How do you get it?
Also you will need the Mootools Upgrade plugin enabled to make all of Kunena work completely, we auto enable it on Kunena pages, but that does not always work. Best way is to have that enabled in the system plugin settings.
It also seems that you are still running the legacy plugin on your site. It is highly recommended to remove that and any remaining Joomla 1.0 software you have installed. Kunena is not tested with the legacy plugin.
15 years 10 months ago #69355 by Zafit0
Sh404ef is installed.
15 years 10 months ago #69367 by xillibit
please use the default sef system integrated into Joomla! because Sh404ef cause some issues
Time to create page: 0.226 seconds
