Question Problem with Virtuemart Lightbox after installing Kunena 1.6
15 years 10 months ago #68712 by Sanyi
Hi Guys,
In the last days I've upgraded Joomla! from version 1.5.18. to 1.5.21. and I have installed Kunena 1.6.
Following these actions Virtuemart product images don't open in Lightbox (like earlier) but in main window. :(
After turning of Mootools upgrade Virtuemart Lightbox opens again and also Kunena 1.6 seems to work normally.
Does Kunena 1.6 need Mootools upgrade to be turned on or not? What should I do when other extensions need Mootools upgarde? I think it is just a temporary/makeshift solution.
What is the nice and correct solution for the above problem (conflict between Kunena 1.6 and Virtuemart Lightbox)?
Many thanks for your help in advance.
Best regards,
Sanyi
"beginner amateur dilettante joomla-fan"
www.vizszintmero.hu
15 years 10 months ago #68720 by xillibit
For the conflict with others lightbox, you need to wait k1.6.1 which including a configuration setting which allow you to disable the lightbox into kunena.
The following user(s) said Thank You: Sanyi
15 years 10 months ago #68726 by Sanyi
Dear xillibit,
Thank you for the answer.
regards,
Sanyi
Time to create page: 0.242 seconds
