Question Personal info
15 years 8 months ago #66286 by uv-jagt.dk
Personal info was created by uv-jagt.dk
I installed Community Builder after K 1.6 and now no longer need the Kunena icons below the avatar (profile info)
I can remove all them but the "Gender icon" ... how do I remove this and can I somehow import the profile info from CB?!
15 years 8 months ago #66292 by sozzled
Replied by sozzled on topic Re: Personal info
I am sure that most of your questions are answered if you browse other topics in this category.
I can't explain how to remove the gender icon (because I haven't looked to see how it might be done other than by hacking the source code). If you decide to remove these things, make sure that you don't change the Default (Blue Eagle) template ... or any other template installed by Kunena.
The following user(s) said Thank You: uv-jagt.dk
15 years 8 months ago - 15 years 8 months ago #66311 by Hurr1c4n3
Replied by Hurr1c4n3 on topic Re: Personal info
Have you set integration to Community builder in Kunena?
After you did that you can change the community builder forum intergration plugin.
[edit]
Hmmzzz did that but only the gender icon stays visible all other icons are gone now.
I see what you mean.
Last edit: 15 years 8 months ago by Hurr1c4n3.
15 years 8 months ago #66312 by uv-jagt.dk
Replied by uv-jagt.dk on topic Re: Personal info
Hurr1c4n3 wrote: Have you set integration to Community builder in Kunena?
[edit]
Hi
What intergration plugin are u referring to?!
15 years 8 months ago #66314 by Hurr1c4n3
Go to the backend.
Click components -> community builder -> plugin management
And then select the forum integration plugin and edit that one on the right side.
15 years 8 months ago #66315 by uv-jagt.dk
Hurr1c4n3 wrote: Go to the backend.
Ok I'm in ... and what do I set "Sidebar settings" to?!
