Question Only admin issue at my site
16 years 1 month ago #65536 by Solarship
Searched here a now 2 days for a solution, but without any luck :(
My Problem:
made an upgrade to K1.6, all smooth, no errors. Can post, can answer posts.
BUT when I'm logged in as administrator and I want to view my profile page in JomSocial, the site is blank. Only the profile. Can access all other pages.
And all other test user can see the profile page.
Played along with plugins, mootools,...
Nothing has changed the status :(
Hope one of you can me help in this issue.
Thx in advance
SolarShip
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 25M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.8) | UddeIm: Disabled or not installed
16 years 1 month ago #65554 by xillibit
Can-you tell if you using the plugin for Jomsocial mykunena which shows user posts in jomsocial profil page ?
This data is missing from my report configuration :(
16 years 1 month ago #65723 by Solarship
yes, I use both plugins: kunena menue and my posts.
I've also tried to disable them, same result and I've tried the one file (mykunena.zip) which was posted in a thread earlier.
SolarShip
16 years 1 month ago #65724 by fxstein
If you get a blank page, please look up your hosts web-server error log and post the error message you see in there. That should point to the problem right away.
The following user(s) said Thank You: Solarship
16 years 1 month ago #66356 by Solarship
Setup system from scratch, now it's working ;)
Thx
SolarShip
