Question Errors Kunena and JomSocial
  • lev
  • lev's Avatar Topic Author
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
15 years 11 months ago - 15 years 11 months ago #65324 by lev
Replied by lev on topic Re: Errors Kunena and JomSocial
500 - JDatabaseMySQL::query: 1054 - Unknown column 'na' in 'where clause' SQL=SELECT COUNT(*) FROM jos_kunena_messages AS m INNER JOIN jos_kunena_messages AS mm ON m.thread = mm.id WHERE m.userid='62' AND mm.moved='0' AND m.moved='0' AND mm.hold IN (0,1,2,3) AND m.hold IN (0,1,2,3) AND mm.catid IN (na)
Call stack
# Function Location
1 JSite->dispatch() /index.php:68
2 JComponentHelper->renderComponent() /includes/application.php:124
3 require_once() /libraries/joomla/application/component/helper.php:162
4 CommunityBaseController->execute() /components/com_community/community.php:178
5 CommunityProfileController->display() /components/com_community/controllers/controller.php:289
6 CommunityProfileController->profile() /components/com_community/controllers/profile.php:889
7 CommunityView->get() /components/com_community/controllers/profile.php:1086
8 CommunityViewProfile->profile() /components/com_community/views/views.php:387
9 CAppPlugins->triggerEvent() /components/com_community/views/profile/view.html.php:509
10 CAppPlugins->_triggerOnProfileDisplay() /components/com_community/libraries/apps.php:250
11 CAppPlugins->renderPlugin() /components/com_community/libraries/apps.php:185
12 plgCommunityMyKunena->onProfileDisplay() /components/com_community/libraries/apps.php:90
13 CKunenaLatestX->getUserPosts() /plugins/community/mykunena.php:55
14 CKunenaLatestX->_getPosts() /components/com_kunena/funcs/latestx.php:342
15 JDatabaseMySQL->loadResult() /components/com_kunena/funcs/latestx.php:260
16 JDatabaseMySQL->query() /libraries/joomla/database/database/mysql.php:355
17 JError->raiseError() /libraries/joomla/database/database/mysql.php:231
18 JError->raise() /libraries/joomla/error/error.php:171
19 JException->__construct() /libraries/joomla/error/error.php:136
Sorry for my English.
Last edit: 15 years 11 months ago by lev.
15 years 11 months ago #65325 by xillibit
The following user(s) said Thank You: lev
  • lev
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
15 years 11 months ago - 15 years 11 months ago #65363 by lev
Hi xillibit,
Now works without error ...))
I did not flattery in the ftp, I replaced in the archive file.
Enables debugging of the system, no errors were found!
Thank you!
  • lev
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
15 years 11 months ago #65377 by lev
Hi xillibit,
Another question about the localization of the plugin.
How do I keep writing in another language?
In the picture "in"...
15 years 11 months ago #65419 by 12Rocket
lev wrote: Hi xillibit,
I have the same question here : www.kunena.com/forum/11-jomsocial/7490-k...it=10&start=10#65190
  • lev
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
15 years 11 months ago - 15 years 11 months ago #65480 by lev
Hi 12Rocket,
Thank you for the link ...)))
Answer to the question just does not ...)))
I tell you how to change the name, there are two or three ways!
1. Change the name of the plugin
2. Change the name of the plug-in component JomSocial
3. We climb and adds to the bottom
ru-RU.com_community.ini
MY KUNENA FORUM POSTS=My Forum Posts
SYSTEM - KUNENA=My Forum Posts
How to edit the rest do not know!
Do not forget all about:
ru-RU.plg_community_mykunena.ini
PLG_COMMUNITY_MYKUNENA_NO_POSTS="%s no forum posts."
Theoretically, this should be so:
IN="" ON=""
or something like this:
%nickname in %name on %date
But it does not work!
The following user(s) said Thank You: 12Rocket
