Question jomsocial 1.1,141 and kunena pm
17 years 6 months ago #6690
by fxstein
Replied by fxstein on topic Re:jomsocial 1.1,141 and kunena pm
We will have to look into what change with JomSocial. Unfortunately we did not get any heads up on this change.
I guess it turns out good that we held back on the 1.0.9 service release for a couple of days. We will try to include a fix for this.
Thx for letting us know!
fxstein
fxstein
17 years 6 months ago #6781
by jonsolo
Replied by jonsolo on topic Re:jomsocial 1.1,141 and kunena pm
Yep, not working in 1.1.142 either...their service release, ha ha.
I looked at the code and cannot figure it out...must be much deeper than me!
- abraxas9083
- Junior Member
17 years 6 months ago #7248
by abraxas9083
Replied by abraxas9083 on topic Re:jomsocial 1.1,141 and kunena pm
have someone a solution ? dont work also in 1.1.144
- noelhunter
- Junior Member
- Thank you received: 1
17 years 6 months ago #7292
by noelhunter
Replied by noelhunter on topic Re:jomsocial 1.1,141 and kunena pm
The problem seems to be that the function has been moved, into
/components/com_community/assets/script-1.2.js
I manually included that in class.kunena.php as follows:
After:
//PM popup requires JomSocial css to be loaded from selected template
$config =& CFactory::getConfig();
Add:
$mainframe->addCustomHeadTag('<script type="text/javascript" src=" www.yoursite.com/components/com_community/assets/script-1.2.js ">');
This is a temporary fix. My understanding is that jomsocial will be offering the fix in a new release.
After:
Add:
- spacereactor
- Senior Member
17 years 6 months ago - 17 years 6 months ago #7295
by spacereactor
Replied by spacereactor on topic Re:jomsocial 1.1,141 and kunena pm
thank for the code, in your class.kunena.php and you only need to add without addin the your website and it still work.
i have upload a file, unzip it and upload to replace it with your current one should work. located at components/com_kunena folder
$mainframe->addCustomHeadTag('<script type="text/javascript" src="/components/com_community/assets/script-1.2.js"></script>');
Last edit: 17 years 6 months ago by spacereactor.
17 years 6 months ago #7362
by jonsolo
First, thank you for compiling the file.
Just a reminder to anyone who has Joomla installed someplace other than the root directory of your website:
You will still need to go into this new config file and change the path to reflect your actual Joomla install path.
For me it was adding /en just before the /componants.
Regards,
Jon
Regards,
Jon
