Question Function "Remember Me" not work
16 years 1 month ago #63588 by Zylkin
When i use login and registration links from CommunityBuilder, function "Remember Me" in forum ant kunena login not work. Every time need to login.
16 years 1 month ago #63636 by sozzled
That's something you will have to take up with the developers of Community Builder.
16 years 1 month ago #63669 by Matias
I'm not 100% sure if it's our bug or in CB. We need to check it out.
16 years 1 month ago #63932 by Zylkin
In CB login module this function works well.
16 years 4 weeks ago #67080 by Bob Britt
I need to add a ME Too on this issue.
Long story short. When we log on with the Kunena log in form we are logged on only for that session. Once the browser is closed and reopened the user is logged out. If we log on via CB module on the main menu we are remembered as intended. I"ve tested this back and forth and Kunena logon form does seem to be the issue.
any advice?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 100M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 1.9)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
16 years 1 week ago #70165 by Zylkin
Why in Kunena 1.6.1 this bug not fixed?
