Question make my forum posts appear under activity
16 years 1 month ago #63522 by vickyjain05
I just installed Jomsocial 1.6 and Kunena..Integrated them from Kunena configuration, but whenever I post in kunena forum, the same does not appear in the activity stream of Jomsocail.
Can some one please help me if I have missed something? I believe that by default all the kunena posts appear under the activity stream of jomsocial.....Please correct me if I am wrong
Have attached the screen shot for reference
16 years 1 month ago #63525 by Matias
Kunena 1.5 only adds posts from public forums int oactivity stream.
Kunena 1.6 can additionally have registered only posts in there.
Neither of them shows messages from Author+ forums.
16 years 1 month ago #63555 by vickyjain05
Hi thanks for the response. But my question was that by default the post comes into the activity stream, but in my case it isnt.
Can you tell me the possible reasons for this? Is there any missing plugin that needs to be installed or is there any setting that needs to be done in Kunena configuration?
16 years 1 month ago #63566 by xillibit
What kunena version do you using ?
To enable activity stream, there is nothing else to enable the configuration setting for it in backend and the new post will be displayed in activity stream.
16 years 1 month ago #63570 by vickyjain05
I am using Kunena 1.5.9.
Is it a version problem? If yes....then how do I upgrade?
16 years 1 month ago #63572 by Matias
Upgrade:
* Try it first in your test site (optional, but I always recommend it as it potentially shortens downtime in the real site)
* Take backup from your site
* Install new version
* Test it
