Question [Split topic] uddeIM DHTML boxes cause loss of Kunena editor Javascript-driven functionality
16 years 2 months ago - 16 years 2 months ago #61668 by zonedabone
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Third-party components: AlphaUserPoints: Enabled (Version : 1.5.10) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Enabled (Version : 2)
Whenever someone posts a reply or starts a new topic, the bbcode options like smiles and formatting don't work. I've seen this when mootools upgrade is disabled, but it is on, and I still have the problem. The only thing that may be related to my knowledge is the recent instalation and integration of UddeIM. When I disabled integration with UddeIM, it still had the problem. Any solutions?
Thanks in advance.
Last edit: 16 years 2 months ago by zonedabone.
16 years 2 months ago - 16 years 2 months ago #61669 by zonedabone
FOUND! The UddeIM notifier module causes problems when used in syndication position. I'll try to find out where I can put it.
EDIT: The module causes problems when the Notification type is set to DHTML Boxes. The floating type works fine.
16 years 2 months ago - 16 years 2 months ago #61671 by sozzled
Thanks for that tip, zonedabone. We always ask people to read the sticky topics about things that people are likely to use with Kunena, like uddeIM. Perhaps you might also like to add this tip to the uddeIM category, as well.
DHTML usually implies that some Javascript is involved (not always, but it's the most commonly-used client-side scripting language for web browsers). Maybe you would like to report your discovery to the developer of uddeIM to see what .js library he's using?
16 years 2 months ago - 16 years 2 months ago #61679 by Mortti
@zonedabone update also your AlphaUserPoints to latest release... in your AUP 1.5.10 version is UddeIM integration bug which cause problems if you have UddeIM integration enabled in AUP and Kunena 1.6 in the same time, this bug is fixed in AUP 1.5.11. --> www.alphaplug.com/index.php/news/177-alp...s-1511-released.html
Edit: and check that you use UddeIM 2.1 and it module(uddeIM Notifier module in 2.1 package), upcoming K 1.6 RC3 version that "Report Configuration Settings" will tell also the exact version of the UddeIM component like 2.0 or 2.1... which help people like sozzled (moderators) in K.com ;)
Mortti
Last edit: 16 years 2 months ago by Mortti.
16 years 2 months ago #61758 by adminthptngochoi
zonedabone wrote: FOUND! The UddeIM notifier module causes problems when used in syndication position. I'll try to find out where I can put it.
Solution ? :(
16 years 2 months ago #61759 by sozzled
I think, in the case of the uddeIM issue, the solution is to not use DHTML boxes.
