Question Please Help: My forum Menu Tabs are Rounded and I do not want them to be
15 years 9 months ago #59863 by Cerberus
in the matter of the CB_Plugin if im am sent a copy of it i will attempt to make it work for K1.6 ( attached it to this thread ) as i have on many other plugins availible from the KED :)
15 years 9 months ago #59868 by sozzled
christian15213 wrote: Whenever I have the CB plugin activated the tabs screw up
Can you please state which specific "CB plugin" you are referring to. Thank you.
15 years 9 months ago #59885 by christian15213
Hi, thanks for the response.
the plugin is called cb.simpleboardtab and the name of the plugin is "Forum Integration"
to answer the other question I only changed the .css of the Kunena not the .min... should I do both?
Lastly, is there anyway you can make that plugin a little better i.e. the thank yous and the add more links?
15 years 9 months ago #59888 by sozzled
The cb.simpleboardtab plugin was not designed by the Kunena project team; it was developed and is supported by Joomlpolis . We've written a few tips to help users of Kunena but this site does not provide comprehensive support for Community Builder.
Please read Minified CSS for the answers to your questions about which CSS files to change.
15 years 9 months ago #59927 by Cerberus
christian15213 wrote: Hi, thanks for the response.
maybe but i would need a copy of the plugin..
15 years 9 months ago #59963 by christian15213
these are all the files in the plugin folder.
I will happily tell you that i changed the min css file and it seems to have worked. should I change the regular css file as well? does it matter? and lastly, if you make the fix can I put the edits back? I don't like the rounded tabs anyway so...
Moreover, if you could add the integration functionality that is the same as the Kunena login. you would be master god almighty and I would want to donate something to you asap. it would be much appreciated.
thanks for your help.
Time to create page: 0.229 seconds
