- Thank you received: 3
Question [SOLVED] Thread Avatars with JomSocial
/com_components/com_kunena/template/default_ex/kunena.forum.css
Let me know how it works!
I cannot put a link to my site because the forum it's only opened to registered users
I created a solution to this.
You need to edit the file called view.php in the folder of the template that you are using. Using default_ex you need to do the following:
Locate the following code:Code:$msg_avatar = '<span class="fb_avatar"><img src="' . $jsuser->getThumbAvatar() . '" alt=" " /></span>';
Replace it with the following code:Code:$msg_avatar = '<span class="fb_avatar"><img src="' . $jsuser->getAvatar() . '" alt=" " /></span>';
Notice that we are now getting the Avatar instead of the ThumbAvatar.
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! .... :laugh:
It works very well.
open file profilebox.php in components/com_kunena/template/default/plugin/profilebox/
see code line 43
edit to
