Kunena 7.0.8 Released
Idea Re: Jomsocial and Kunena questions
16 years 3 months ago - 16 years 3 months ago #48320 by Lord Zedd
Hello there,
I got a couple of questions which I hope can be answered. The website in question :
www.stargateonline.be/forum
1. I would like to have a bigger avatar on the Kunena forums. When I go to the Kunena administrator backend in Joomla, I go to Kunena configuration > Integration > Avatars. I select JomSocial.
For profile settings and Pms I also select Jomsocial. When I go to Kunena confiruation > Avatars you can change the size. I did that but the avatar size remains the same. My avatar sizes are 64px x 64px. How can I solve this?
2. I noticed when visiting here my own profile (that of Jomsocial) that it says : I replied to my other threads like this :
Lord Zedd replied to the topic Re: No white spaces between lines in posts in the forums.
How can I have the same thing on my forum? The applications you got here in the JomSocial : My Kunena Forum Menu and My Kunena Forum Posts. Where do I download them?
3. I have a weird problem that I can not seem to solve. I do not understand it. It is regarding login in and out of Kunena and Jomsocial. Perhaps it is an error of Jomsocial and not Kunena. I do not really know.
I am visiting my own forum under my account. I select logout. I am directed to the Jomsocial frontpage. I am not logged out. When I select "Log out" on the right side in Jomsocial frontpage, I am effectively logged out. I than get a weird message that I need to login.
I am visiting my own forum as a normal guest. I select on the forum login. I am directed to the Jomsocial frontpage where it says become a member and an option to login. I enter my username and password. I select login. Than I get the same weird message that I need to login.
I really do not understand it myself. I am using the Hello me module on the website aswell but I do not think the problem lays there. It is confusing, I know but if you could take a look at it please, it would be really appreciated!
4. How can my users have signatures in Kunena while their profile is managed by Jomsocial?
Thank you for your time!
Lord Zedd
Last edit: 16 years 3 months ago by Lord Zedd.
16 years 3 months ago #48333 by Cerberus
1. jomsocial is controling your avatar so kunena setting will have no affect
2. i have no idea on this one as i dont use jomsocial
3. login is controled by joomla and not kunena.
4. no profile setting in kunena will work if jomsocial is controling your profile, so signiture would have to be set in jomsocial ( if thats even possible??? )
16 years 3 months ago #48345 by Lord Zedd
Thank you for your reply but not all my questions are answered.
1. Yes, I know that if Jomsocial manages the avatars and profiles the settings that I entered in Kunena will have 0 effect. Stil the avatars are very small.
2. It is a plugin that the developpers of Kunena will release but when ... I do not know.
3. I need more help here.
As for question 4, I figure it is possible with a plugin the developperes of Kunena have developped. www.kunena.com/forum/76-official-announc...ykunenatoolbar#34880
16 years 3 months ago #48349 by xillibit
2°) You need to enable the activity stream in kunena configuration panel and look this : joomlacode.org/gf/project/kunena/frs/?ac...&frs_package_id=5011
3°) This point is not very clear for me
4°) It's not possible, you need to edit your signature by kunena profile
16 years 3 months ago #48361 by sozzled
The avatar image size problem existed in K 1.5.9. It was corrected in K 1.5.11. You should upgrade immediately to K 1.5.11. B)
16 years 3 months ago - 6 years 2 months ago #48370 by jwd.adodis
Hello All
Your image Size is large.It was corrected imaze size in K 1.5.11.
so you can upgrade immediately.
Last edit: 6 years 2 months ago by rich. Reason: Link removed
Time to create page: 0.229 seconds
