Question Group Jive Not So Private Forums
16 years 8 months ago #39301 by Matias
Are you sure that you have set GJ to have only private groups? With public groups this is what I expect it to do..
There is one way to get private forum: changing pub_access field to 1 in phpmyadmin. I do not generally recommend doing this, but now there are no other choices.. :( I will mark this bug to be fixed to K1.6.
16 years 8 months ago #39349 by GWS2
Do you mean by this that the Groupjive catgeory in Kunena (that contain all groupjive forums) is disabled...yes.
As I said, the main forum created by GJ is private. My concern is the sub-forum/category added to this private forum (in kunena (forum admin), which does not share the same privacy.
Will try
for the sub-catgegory of the private forum, to see if that fixes it, and get back to you.
Thanks laot for your suggestion.
16 years 8 months ago #39708 by GWS2
Hi Have tried changing public_access field of groupjive sub forums as suggested:
but got no joy.
The result was that no registered members could see the sub-forums, that is, they could view their main private group forum, but could not see any sub forums created manually in Kunena's Forum Administration.
Back to the drawing board.
16 years 7 months ago #41920 by williamhill77
ya same with me. I too tried but struck with the same.
Acai Colon Cleanse
Colon Cleanse Teeth Whitening
16 years 7 months ago #41924 by GWS2
Hi
Worked around this by:
1.Raising 'Public Access Level' of sub forum, from Registred to Author.
2. Then, Making group members of required gpoup, Moderators of that particular sub forum.
This dawned on me after re-reading the follwing paragraph, next to the 'Public access' select box in Forum Administration.
To create a non-public Forum, you can specify the minimum user level that can see/enter the forum here. By default, the minumum user level is set to "Everybody".
Please note: If you restrict the access of a whole category to one or more certain groups, you will hide all forums it contains to anybody not having proper privileges for the category even if one or more of these Forums has a lower access level set! This is also true for moderators. You will need to add a moderator to the category moderator list if they do not have the proper group level to see the category.
Categories cannot be moderated, but moderators can still be added to the moderator list.
This workaround for Groupjive sub forums would not be practical where groups have large memberships.
16 years 7 months ago #42173 by krileon
Known issue with GJ 1.8 API usage; GJ 1.8 is final and won't be receiving further updates. GJ 2.0 feature in our workgroups ( cbworkgroups.joomlapolis.com/ if you'd like to sign up) has not yet released a forum integration, which will have better controls of privacy.
