Question 1.5.7 Jomsocial Activity and points?
16 years 5 months ago #33436 by mysfowner
I dont see where you configure this ...I see alpha userpoints in the backend and thats it
16 years 5 months ago - 16 years 5 months ago #33522 by mysfowner
Does anyone know how to get this working?
Last edit: 16 years 5 months ago by mysfowner.
16 years 5 months ago #33524 by halo3montage
I believe its automatic, once I upgraded it worked flawlessly.
By the way,thanks for the integration Kunena!
16 years 5 months ago #33525 by fxstein
Correct. Once you select JomSocial for profile integration, the activity stream and points are automatic.
16 years 5 months ago #33539 by doone
Hello.
I can't get the activity stream to work.
I tried completely uninstalling the old version of Kunena. I checked these files:
components/com_kunena
administrator/components/com_kunena
images/fbfiles
I found that images/fbfiles were still there, so I deleted them.
Then I installed Kunena 1.5.7.
Went to configuration - integration. It still said it was integrated with JomSocial.
So I checked the forum on the front end.
The old forums still existed. Tried adding a new post anyhow to see if the activity stream worked. It didn't.
Not sure what else to try.
BTW, so far as I can tell, this Kunena upgrade fixed issues I had with using RT's Affinity template :). I hadn't been using Kunena because of the problems, but figured I'd give it a whirl again. If I can get this JomSocial issue fixed, I'll certainly be using Kunena :silly:
16 years 5 months ago #33540 by Djie
It works flawlessly but not in a very good way when we are talking about options. The actvity stream is now flooded with only forum messages which above all do not point to the message written bij the user (or last message in a thread) but points to the thread/topic start message.
Is it possible to turn the integration off in the activitystream? Or is it possible to only show new threads in the activity stream?
Time to create page: 0.279 seconds
