Question Problems detected in Community Builder integration
17 years 3 months ago #27258 by RichRawlings
# Community Builder Profile integration only works if Community Builder User profile has been published.
# Saving the Kunena configuration will disable integration and hide this warning.
I don't want to disable integration. I want to use Community Builder with Kunena.
Thanks for any help with this.
www.usmjparty.com
17 years 2 months ago #28105 by carsten888
same prob here. did find a solution?
17 years 2 months ago #28109 by @quila
17 years 2 months ago #28136 by carsten888
thanks, that was really usefull.
now I am stuck because at the profile-edit-page the data in the forum-settings are not saved. Posted that on the CB forum.
