Question Signatures and message ordering for Community Builder users
The current situation, as I understand it, is that Kunena developers are working with CB developers; CB's development team had other priorities that have prevented them completing their work in time for the release of Kunena 1.0.9. At the moment, it is definitely possible to use Kunena 1.0.9 with Community Builder 1.2, however there is no "official" solution: the solution is obtained by users having to perform a few hacks and workarounds. It is possible that these non-automated procedures may need to be reapplied in the future releases of either software but we're forever hopeful that the problems we've experienced for the past three months will be overcome soon.
Joomlapolis has refrained from providing details of the timeframe for when the Community Builder development activities will be completed.
In the meantime ...
It is possible, using the famous Tony Woodhouse kludge , to implement the CB forum tab. It's childsplay and I've never had any problems with it.
The only problem that hasn't been solved is the ability to modify, from a user's Community Builder profile, the message ordering and signature for the forum. The simplest solution that I've found is to completely disable the ability to edit these settings in Community Builder (it's merely a matter of unpublishing a tab).
The next matter is how to allow users the means to change message ordering and/or their signatures. Again, the solution is simple: don't use Community Builder profiles when your configuring Kunena.
OK, I agree that nobbling CB has disadvantages - not the least of which is that it confuses the users as to how and where they have to adjust certain settings - and we might ask why these two products dont work together causing us to have to duplicate things unnecessarily. But that's the price to pay, in the short term, if we're going to tackle important issues.
As long as it concerns signatures and message ordering (and involves Community Builder and Kunena, obviously), if anyone wants specific details on what settings need to be changed, please respond to this thread.
Cheers
sozz
- mjanzen128
- Junior Member
- Thank you received: 1
BUT make sure you have all those profile options and make sure the cb_whatever it is is correct or you might have issues.
Thank you.
- mjanzen128
- Junior Member
I think this statement means, add the following fields to your CB user database: gender, personaltext, icq, location, birthday, showage, aim, msn, yim, skype, gtalk, websiteurl, websitename, signature. Why would you need to add another field for signature when there's already one inbuilt. Would this not also conflict with the "standard" CB profile editing feature that allows users to change their signature?BUT make sure you have all those profile options and make sure the cb_whatever it is is correct or you might have issues.
Can you confirm that my guesses about these additional fields are correct (not just for my benefit but also for others who may be interested in this discussion)? Thanks.
- mjanzen128
- Junior Member
And yes, it seems like it would conflict, but it doesnt. Even if you have CB enabled show the profile in Kunena (which you need it to work the code I have up there) it won't conflict at all.
