Question [SOLVED] 1.09 - Fatal error: Class 'CKunenaCBProfile' not found in ....... Line 175
17 years 4 weeks ago - 17 years 3 weeks ago #10645 by tamerax
Running Joomla 1.5.10
Community Builder 1.2
Was running Kunena 1.08 just fine.
Uninstalled old verion of Kunena. Installed 1.0.9 and it said it upgraded fine. I can access the backend with no issues but when i try to load my site, i get this error:
Fatal error: Class 'CKunenaCBProfile' not found in ..../components/com_kunena/lib/kunena.link.class.php on line 175\
Oh yeah, I also recreated my main menu link because it got erased in the transition.
Any help would be amazing as my site is kinda dead right now :P
Thanks!!
update: When I disable mod_kunenalatest, it loads up again.
Last edit: 17 years 3 weeks ago by fxstein.
17 years 4 weeks ago #10646 by eezz
I suggest that you restore from backup if you need your site up asap... otherwise, give the dev's a chance to find out what might be the issue.
17 years 4 weeks ago #10647 by tamerax
it has something to do with the mod_kunenalatest. I disabled it and it loads up again. Gonna try to reinstall the module and see what happens.
17 years 4 weeks ago #10656 by kai920
maybe the module needs to be updated?
Naming Changes:
+ Renamed fbUserprofile to CKunenaUserprofile. It can be found from lib/kunena.user.class.php
17 years 4 weeks ago - 17 years 4 weeks ago #10660 by koraykupe
Delete %T and close profile links in kunena latest module for now. It needs to be updated.
Last edit: 17 years 4 weeks ago by koraykupe.
17 years 3 weeks ago #10841 by Pumuckl
Time to create page: 0.262 seconds
