Question Kunena 1.0.10 + Kunena 1.0.11 - Change Profilebox to the left side and textbox on right side
16 years 11 months ago #19917 by ph-jps
Can someone help me to do this with 1.5.3? I'm not that good in coding stuff :blush:
16 years 10 months ago #23312 by Lintzy
Kunena 1.0.11 contains the same messagbox.php file as in 1.0.10. So you can use this here vor 1.0.11 too.
  • don gilbert
  • don gilbert's Avatar
  • New Member
  • New Member
16 years 8 months ago - 16 years 8 months ago #27316 by don gilbert
grumblemarc wrote:
No. You shouldn't be using it. No one should be developing templates nor offering fixes for it. It is for bug testing and reporting only.
Well somebody's a grumble goose. Give a person a break.
ph-jps wrote:
Does someone has this for 1.5.1b? :blush:
I just implemented this in J!1.5.14 and Kunena 1.5.5 and it works flawlessly. Uploaded the new message.php and made the css adjustments. Thanks Lintzy!
Last edit: 16 years 8 months ago by don gilbert.
16 years 7 months ago #29958 by Jingz
It worked in my Kunena 1.0.11.... Thanks a lot guys. Nice work! ;)
16 years 7 months ago - 16 years 7 months ago #30382 by 450Thumper
Thanks for the great info. However, when I made these changes it altered the tables where the reply icons are above and below as well as the message box. I also lost the left forum border. Any ideas how to fix this easily?
See image below.
Live site: www.motoutah.com
Another image (cutting off the right);
Last edit: 16 years 7 months ago by 450Thumper.
16 years 7 months ago #30801 by 450Thumper
Replied by 450Thumper on topic Lintzy - Help!
Lintzy,
My problem in the above pics looks like something you could figure out in a snap. :)
I looked at the two boxes in the message.php that I think are causing the problems and made fixes, but no change to overall layout. It appears that the setting for "New Thread" and "Merge" needs to be made smaller and the other reply button box made much larger. Same on the box below and then setting up a parameter for the view message pane.
Any ideas?
Time to create page: 0.273 seconds
