Question Web 2.0 Templates for Kunena
17 years 2 months ago #7216 by johnnydement
Spock, I really like the template your using for your site forums, I hope you disclose it too someday :)
17 years 2 months ago #7255 by Spock
I did it's the MOClite template and can be downloaded on my site.
17 years 1 month ago - 17 years 1 month ago #8284 by VReyes
Thanks for the dark template.
Last edit: 17 years 1 month ago by VReyes.
17 years 2 weeks ago #12414 by bubbawubba
I am testing the MOCLite template
I am wondering if there is a way to improve the icons.
1. The text is VERY BOLD
2. The same icons are above and below the message. I would like to see the icons only below the message.
3. It seems that the icons are divided into two columns. Would it be possible to have all the icons in one row below the message?
17 years 2 weeks ago #12415 by grumblemarc
I hope ou get a response. His site is down.
17 years 2 weeks ago - 17 years 2 weeks ago #12464 by Spock
bubbawubba,
I'll try to answer you as best i can. Remember that these are based on and are identical to the default_ex template and is only a different style sheet and icons! I didn't touch the PHP layout files.
1. I've attached the blank icons as they appear in the template directory. They're in a zip file and as .PNG files. So you can add whatever font suits your template and can scale them down if you wish (something i should have done).
File Attachment:
File Name: MOC_lite_icons.zip
File Size:28.49 KB
2. These icons aren't the "same". the ones on top refer to the topic as a whole and the ones below are just for each individual post. It's important that you keep both.
3. Only administrators or moderators will see two rows of icons - not registered board members(so in this instance I don't think its that important) . The second row of icons are for board administration tasks. However if you want tosort this out I did have a look at this before and as far I can remember it can be changed in the layout.php, but then you'll have to have a very wide template to deal with all icons in one row!
and my site is back to normal again :)
Reagrds
Mark
Last edit: 17 years 2 weeks ago by Spock. Reason: added a bit more detail
Time to create page: 0.339 seconds
