Solved Error with Kunena Forum Importer Component
14 years 9 months ago - 14 years 6 months ago #118558 by cleweb
Hi
I try to migrate my phpbb3 to kunena (1.7.2), Joomla 2.5.1 and Jomsocial 2.4.2
with Kunena Forum Importer in "Importer status information" i have :
Kunena vers 1.7.2 green
my relative path in green
detecting phpbb3 ok green
database connection : ok green
phpbb3 vers 3.0.2 in RED
Error: Unsupported forum: phpBB3 3.0.2
I understant the importer doesn't work with all phpbb3 vers
so with which version is supported ? Think i have to upgrade phpbb3 after ?
thanks in advance for your reply
rgds
Last edit: 14 years 6 months ago by sozzled. Reason: Change topic icon
14 years 9 months ago #118635 by xillibit
In kunena Importer 1.7.1; the minimum version of phpbb3 supported is the 3.0.8
14 years 6 months ago #124197 by jimbrooking
Same error:
phpBB3 version: Error: Unsupported forum: phpBB3
Running phpBB3 version 3.0.10. Where does the importer pick up the version number, as it's reporting a blank for my version.
Thanks.
14 years 6 months ago #124213 by Matias
In export_phpbb3.php
Please tell if you can solve the issue.
14 years 6 months ago - 14 years 6 months ago #124307 by jimbrooking
I am not familiar enough with Joomla internals. I did find the function getVersion() in exportphpbb3.php, and I saw the statement
$query = "SELECT config_value FROM #__config WHERE config_name='version'";
My database (MySQL) is named "fearrin1_phpbb3" and contains a table named phpbb_config. This table contains a "version" row with value "3.0.10". So --- what do I do now?
Last edit: 14 years 6 months ago by jimbrooking. Reason: Correct version .
14 years 6 months ago #124308 by Matias
It should work.
Enable debug in Joomla and check if you see database query like that inside debug messages. I'm not 100% sure if it will show up, but let's hope that Joomla catches it.
