Question Plugin search and strange problem
15 years 3 months ago #99763 by joomlauser
hello everybody,
I have Joomla 1.5.23 and kunana 1.6.4 + plugin search v1.6.4 +
Kunena Search 1.6.4 - what is so strange - when I turn on "Use Apache mod_rewrite" I get en error during searching my site like this:
The request /forum/index/advsearch.html was not found on this server.
but when I turn off The request "Use Apache mod_rewrite" everything works as it should.
How to solve that mayby the problem is hattacess?
this is how it looks mine:
## # @version $Id: htaccess.txt 21064 2011-04-03 22:12:19Z dextercowley $ # @package Joomla # @copyright Copyright (C) 2005 - 2010 Open Source Matters. All rights reserved. # @license http://www.gnu.org/copyleft/gpl.html GNU/GPL # Joomla! is Free Software ## ##################################################### # READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE # # The line just below this section: 'Options +FollowSymLinks' may cause problems # with some server configurations. It is required for use of mod_rewrite, but may already # be set by your server administrator in a way that dissallows changing it in # your .htaccess file. If using it causes your server to error out, comment it out (add # to # beginning of line), reload your site in your browser and test your sef url's. If they work, # it has been set by your server administrator and you do not need it set here. # ##################################################### ## Can be commented out if causes errors, see notes above. Options +FollowSymLinks # # mod_rewrite in use RewriteEngine On ########## Begin - Rewrite rules to block out some common exploits ## If you experience problems on your site block out the operations listed below ## This attempts to block the most common type of exploit `attempts` to Joomla! # ## Deny access to extension xml files (uncomment out to activate) #<Files ~ "\.xml$"> #Order allow,deny #Deny from all #Satisfy all #</Files> ## End of deny access to extension xml files # Block out any script trying to set a mosConfig value through the URL RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR] # Block out any script trying to base64_encode data within the URL RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR] # Block out any script that includes a <script> tag in URL RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR] # Block out any script trying to set a PHP GLOBALS variable via URL RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR] # Block out any script trying to modify a _REQUEST variable via URL RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2}) # Return 403 Forbidden header and show the content of the root homepage RewriteRule .* index.php [F] # ########## End - Rewrite rules to block out some common exploits ########## Begin - Custom redirects # # If you need to redirect some pages, or set a canonical non-www to # www redirect (or vice versa), place that code here. Ensure those # redirects use the correct RewriteRule syntax and the [R=301,L] flags. # ########## End - Custom redirects # Uncomment following line if your webserver's URL # is not directly related to physical file paths. # Update Your Joomla! Directory (just / for root) # RewriteBase / ########## Begin - Joomla! core SEF Section # RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] # # If the requested path and file is not /index.php and the request # has not already been internally rewritten to the index.php script RewriteCond %{REQUEST_URI} !^/index\.php # and the request is for root, or for an extensionless URL, or the # requested URL ends with one of the listed extensions RewriteCond %{REQUEST_URI} (/[^.]*|\.(php|html?|feed|pdf|raw))$ [NC] # and the requested path and file doesn't directly match a physical file RewriteCond %{REQUEST_FILENAME} !-f # and the requested path and file doesn't directly match a physical folder RewriteCond %{REQUEST_FILENAME} !-d # internally rewrite the request to the index.php script RewriteRule .* index.php [L] # ########## End - Joomla! core SEF Section
My enviroment:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : ja_teline_iii_v2 | author: JoomlArt.com | version: 1.0.0 | creationdate: 19 Oct 10
Third-party components: UddeIm 2.3
Third-party SEF components: ARTIO JoomSEF 3.8.2
Modules: Kunena Latest 1.6.4 | Kunena Login 1.6.4 | Kunena Search 1.6.4
15 years 3 months ago #99997 by Matias
htaccess file looks good and should redirect this URL -- as long as your Joomla installation is in server root. Is it?
15 years 3 months ago #100608 by joomlauser
Yes it is
15 years 3 months ago #100651 by sozzled
The only contribution I can make to this topic is to read Search Engine Optimisation (SEO) . I'm sorry, I don't have any other suggestions to contribute here. Please note that the htaccess.txt file that is shipped with Joomla 1.5.23 is designed to work with Apache web servers. Other web servers (e.g. IdeaWebServer/v0.70) may require more customising. Please contact the Joomla forum ( forum.joomla.org ) for any special considerations involving Joomla SEO and IdeaWebServer technology.
Time to create page: 0.159 seconds
