Question Conflict with My Kunena Forum Posts (plugin for JomSocial)
15 years 10 months ago #78279 by likemandrake
I'm using Joomla 1.5.22, AceSEF 1.5.10 (with Kunena extension and without JomSocial extension), Kunena 1.6.1, mod_kunenalatest 1.6.0-RC2, My Kunena Forum Posts 1.6.0-RC1, JomSocial 2.0.2 and PHP XDebug enabled.
On JomSocial user profile page (not own profile), when I'm not authenticated and mod_kunenalatest and My Kunena Forum Posts are enabled, I get error (showed by Joomla error.php template):
JDatabaseMySQL::query: 1054 - Unknown column 'na' in 'where clause' SQL=SELECT COUNT(*) FROM jos_kunena_messages AS m INNER JOIN jos_kunena_messages AS mm ON m.thread = mm.id WHERE m.userid='62' AND mm.moved='0' AND m.moved='0' AND mm.hold IN (0) AND m.hold IN (0) AND mm.catid IN (na)
When AceSEF is uninstalled, I get Joomla error message (on Joomla index.php template):
* Kunena COM_KUNENA_INTERNAL_ERROR
* Kunena Błąd wewnętrzny: Proszę o kontakt z administratorem serwisu aby rozwiązać ten problem!
That means: Kunena internal error: Please contact your site administrator to solve this problem.
On module I see:
No messages to display
And on JomSocial plugin:
User has no forum posts.
Kind Regards
Piotr Minkina
PS: Sorry for my English.
15 years 10 months ago #78296 by xillibit
This is a known issue in this plugin and it will be fixed in the next release. Thanks anyway for report.
15 years 10 months ago #78503 by likemandrake
Thanks for reply. I'm looking forward for new release.Good luck!
Kind Regards
Piotr Minkina
15 years 8 months ago #86284 by likemandrake
If anyone has the same problem and can not wait to release a fix should edit file plugins/community/mykunena.php. On line 49, between
$user = CFactory::getRequestUser ();
and
if ($user->id) {
must add
KunenaFactory::getSession(true);
Best Regards
Piotr Minkina
