Question Problem with horizontal display
15 years 11 months ago #71454 by Diaspro
Hello everyone. I did not know where to turn if not to you.
I use mod_kunenalatest and I found a problem.
I want to make the module horizontal but when I change the settings it does not change
how can I do?
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 180 seconds | Max execution memory: 128M | Max file upload: 16M
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
15 years 11 months ago #71549 by sozzled
G'day, Diaspro and welcome to Kunena.
There is no support for K 1.6.0-RC2. Please upgrade to K 1.6.1 immediately.
15 years 10 months ago #79554 by sorema
i have 1.6.2 is this horizontal display feautere not yet developed or is my fault? i can't get this module show horizontally, maybe with columns..
thank you
15 years 10 months ago - 15 years 10 months ago #79628 by 2078b54a0a6a52c894ea0efa
I have exactly the same problem - changing from vertical to horizontal has no effect - latest posts are all shown in a column instead of next to each other in a row ? Using 1.6.2 component and module
Any ideas ?
Last edit: 15 years 10 months ago by 2078b54a0a6a52c894ea0efa.
15 years 10 months ago #79699 by xillibit
Horizontal display is not yet implemented in the module for now
15 years 10 months ago #79713 by 2078b54a0a6a52c894ea0efa
Ahh.. now that's helpful to know - there's me thinking there was something wrong with my install. So, any idea when this will be implemented ?
Also, are developers open to developing an alternative horizontal view on a 1 'horizontal' post per row basis ie. not just as an x amount of 'vertical' boxed posts per row?
See here for an example of Recent Forum Posts of what I mean.. to me this looks simple, clean and effective
Thx
