Question variable display issue with mod_kunenalatest
Maybe there is some king of conflict wiht your Joomla! tempalte.
How would you go and troubleshoot this, considering it doesn't happen very often? (and no I can't run the site for 1 week on a different template expecting the error to appear).
Are you refereeing to the green text "MOD_KUNENA_LATEST_PARAM" ? This you can change to whatever you like in the backend of the module. Try change it to "new!". You will only see this string as logged in and for messages you don't have read, can this cause the randomness you refer to?
Cheers!
Visit the Kunena documantation .
Anyway my problem is solved. Thank you very much.
