Question Kunena Latest Posts Module
16 years 2 months ago #62116 by MJW
Hello, First I would like to thank you, I like Kunena 1.6 very much indeed. I have been using the Latest posts module 1.6.0-RC1 2010-08-18 very successfully on my home page for a few weeks now, there have been scrambling problems with it if I show it on other pages but the home page has been fine. I was pleased to see that RC2 has now been released. I wasnt sure whether or not to uninstall RC1 first before installing RC2 so I tried installing RC2 without uninstalling RC1. It looked OK from the backend, RC1 disappeared and all the info for RC2 appeared. I edited the module but I only got this message in the front end.
"ERROR: mod_kunenalatest: Kunena 1.6.0-RC2 (or later) is not installed on your system!"
Have I done something wrong? I have been able to uninstall RC2 and RC1 is installed and working now but obviously I suspect it would be better to have RC2. I would much appreciate some help please.
16 years 2 months ago #62117 by fxstein
If you want ro use the RC2 of the module you need at least the RC2 of Kunena as well.
I recommend you upgrade Kunena to the latest RC3 and the update the module.
Hope this helps!
The following user(s) said Thank You: MJW
16 years 2 months ago #62118 by MJW
Replied by MJW on topic Re: Kunena Latest Posts Module
Thank you very much indeed for such a really quick reply. I was actually using Kunena RC2 but now I have upgraded to RC3 the module does indeed work and it works well. Thank you, it did help, it did the trick.:)
16 years 2 months ago #62181 by riaan007
Where can I get "Latest posts module 1.6.0-RC1" or for RC3
16 years 2 months ago #62182 by MJW
Hello, I got the module from extensions.joomla.org/search?q=kunena+extensions
Best wishes.
16 years 2 months ago #62431 by darksoul
im experiencing problems with RC3... nothing is displayed!!
