Question Latest JE for Kunena does not work with K 1.7 and clashes with Kunena Latest module
14 years 9 months ago #114906 by oates
Hi all,
Seems that the Kunena Latest mod. clashes with other mods such as slideshow (yootheme.com -http://www.yootheme.com/widgetkit) and other mods. Just wondering how to go about troubleshooting it.
I tried Latest JE and it worked, although it looks crappy compared to kunena latest.
If I turn off kunena latest, all other mods work.
This is the final step to resolve in the dev. of our new site. hoping someone can set me in the right direction.
14 years 9 months ago #115143 by xillibit
What issue do you encounter exactly ?
The following user(s) said Thank You: oates
14 years 9 months ago #115154 by oates
Hi Xillibit,
Thank you kindly for responding.
Ok, check this URL for example: www.yootheme.com/demo/joomla/corona
enter a search word, for example 'frame' you will notice a circle spin and a suggestive search result load like google. This feature in addition to a slideshow feature do not work/load in the presence of the kunena_latest mod. So if you can perhaps look at the source code on this url, maybe you might have an idea to workaround.
PS - Latest JE doesn't conflict just Kunena_Latest (which is very nice BTW). If I turn off Kunena_Latest, the problem goes away.
14 years 9 months ago #115168 by sozzled
Looks to me like a question that you need to ask Yootheme. The spinning circle effect merely suggests some kind of AJAX operation. We don't know anything about that.
I don't understand what you mean by JE. Joomla extensions, perhaps? Which JE, specifically? Is this something localised to Yootheme templates? It may be true: Yootheme templates don't work with the Kunena Latest module - for background reading, see My Joomla site template makes a mess of Kunena Unfortunately, these things happen and we're sorry to hear that you have problems with Yootheme templates (or one of them) in the way you described.
If we're going to investigate a cause-and-effect relationship between Kunena Latest and Yootheme templates, we're going to need a test site with these things on it and details about how the site is configured. Your configuration report may help someone understand more. However, as I mentioned earlier, maybe this is just one of those things that we can't fix from our end and maybe this is something that needs the Yootheme community to investigate.
14 years 9 months ago #115171 by oates
thanks again.
As for Latest JE - it is this outdated module: extensions.joomla.org/extensions/extensi...orum-extensions/7393
Ironically, it does not conflict with the AJAX etc. you mentioned. I have opened up a discussion on the Yootheme side too, let's see.
Based on Latest JE working and not causing any conflict, any idea?
14 years 9 months ago - 14 years 9 months ago #115175 by sozzled
Thanks for the explanation. I think it's safe to say that Latest JE for Kunena is a problem. It's good that the developers of Latest JE for Kunena have placed an advisory notice in the Joomla Extensions Directory warning people that their product does not work with K 1.6. By extension K 1.7 (which is not significantly different in structural terms to K 1.6) is no different. If the "Kunena" mentioned in extension name Latest JE for Kunena means K 1.5 then you have an answer. K 1.5 is no longer maintained or supported by the Kunena project team.
The Kunena project team makes no other comment about Latest JE for Kunena. Latest JE for Kunena is not endorsed in any way by the Kunena project team. The listing in the JED makes it quite clear that Latest JE for Kunena was designed for K 1.5. The listing in the JED strongly suggests that it does not work for K 1.6 (and therefore, by extension, K 1.7). I think we have our answer.
I have changed the subject to reflect advice you gave us in response to our question about this "Latest JE" reference you made in your original posting. Thank you for that information, and your report, and I think other people will find this information useful.
Last edit: 14 years 9 months ago by sozzled.
