Question Find Problem
15 years 4 months ago - 15 years 4 months ago #99898 by Svog
Find Problem was created by Svog
Hi.
In file kunenadiscuss.php instead of
$isFrontPage = JRequest::getVar ( 'view' ) == 'frontpage';
should be
$isFrontPage = JRequest::getVar ( 'view' ) == 'featured';
Last edit: 15 years 4 months ago by Svog.
The following user(s) said Thank You: chris.york
15 years 4 months ago #99899 by xillibit
Replied by xillibit on topic Re: Find Problem
I don't understand exactly the purpose of this change
15 years 4 months ago - 15 years 4 months ago #99914 by Svog
Replied by Svog on topic Re: Find Problem
Without these changes, the plugin is not working.
15 years 4 months ago #99947 by chris.york
Replied by chris.york on topic Re: Find Problem
This change appears to work in J1.6 (don't know if it would work on 1.5 - I don't know if there might need to be both expressions so that the plugin works with J1.6 and J1.5?)
Thanks for that suggestion!
However, it doesn't seem to work with the version of Discuss that fixes the '1' issue (I've changed 'frontpage' to 'featured' in both versions and the options only work in the original plugin). I'll live the the '1' so that I can use the plugin.
Hope this helps with solving the problems.
Cheers
15 years 4 months ago #99992 by Matias
Replied by Matias on topic Re: Find Problem
Actually I have already fixed this issue (which is only in Joomla 1.6). The name is different on Joomla 1.6 than it was in Joomla 1.5.
We have also fixed that '1' issue, so just wait for the next release. :)
15 years 4 months ago #99996 by chris.york
Wait? Oh, we're all much too impatient for that! :)
Thanks for solving it... and thanks to the 'fix' I can use the existing version meantime - had a user complain to me that they couldn't comment, so at least I've been able to be responsive. Finger now poised on the download button...
All the best.
