Important Problem with Kunena Discuss Plugin v.1.6.4
15 years 6 months ago - 15 years 6 months ago #94303 by etkritikonspoudon
I am having a problem with the Kunena Discuss 1.6.4
Specifically, if I have not enabled "quick reply", I get this text within at the bottom of the article...
Can you help out?
Cheers
htaccess: Exists | PHP environment: Max execution time: 30M seconds | Max execution memory: 64M | Max file upload: 20M
Joomla default template details : rt_versatility4_j15 | author: RocketTheme, LLC | version: 1.5.4 | creationdate: August 20, 2010
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.6.2 | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4
Last edit: 15 years 6 months ago by etkritikonspoudon.
15 years 6 months ago #94304 by 810
its a missing language string. please open your language file in the kunena discuss plugin dir. and add that string.
Regards 810
15 years 6 months ago - 15 years 6 months ago #94309 by etkritikonspoudon
810 wrote: its a missing language string. please open your language file in the kunena discuss plugin dir. and add that string.
Regards 810
Thank you for your answer @810...
It seems you are correct, as I checked/compared the included Greek and English locale and they are different.
So I have to ask how come Kunena continues to maintain a locale file that is way too old, since a perfectly updated version of the Greek locale is available that has no missing strings (it seems these were not updated even for English from 1.6.2>1.6.4) and has been posted in Kunena forum by yours truly...
You can find it here
ns1.kunena.org/forum/166/88018-greek-tra...r-kunena-discuss-162
The only existing difference between is the number version of the Kunena Discuss plugin in the locale file (1.6.2 instead of 1.6.4)
