Question "Posts in discussion' and 'Read more" Links AND a plugin conflict AND requests
15 years 8 months ago - 15 years 8 months ago #88115 by etkritikonspoudon
First of all, thank you for this great plugin...it's a great concept, if offers great functionality and it looks much better than I thought it would...
I have, however, come across an issue...the "Posts in discussion" and "Read more" links are broken, or rather they are missing their topic id, so they lead to the forum catalogue instead. I have verified this both with automatic topic creation and with Custom topics, where the ID is set..
- If Quick Reply is enabled, one can add one's comment so he/she does not actually HAVE to click on any link. In this case however, having the above links available BEFORE any reply is added does not serve much purpose and it looks weird to have two links one just after the other, both having the same path. After that of course, it can be used to lead one to the forum in order to read all the replies...
- If Quick Reply is disabled, then there already is a link put there which actually leads to the right topic, so making the above links available when quick reply is disabled, I believe serves no purpose, i.e they could be removed from display.
So here you have my requests:
1) Having these links not to appear at all when quick reply is disabled
2) have them appear only after a reply is added when quick reply is enabled.
3) Including Pagination for the replies, so that it can all operate without ever visiting the forum, yet having full access to all the replies, not just a definite number of them.
I have also witnessed a weird conflict of Kunena discuss with ITSocialButtons - a social bookmarks - joomla plugin.
When the latter is enabled, then when I click on any link in the article page to go the forums, I am lead to an almost blank page, with just the text elements of the topic (but no actual layout) where the character encoding is all messed up (this might not happen with latin characters, but I use greek) and a fatal error is displayed for the ITSocialButtons plugin.
Fatal error: Class 'ContentHelperRoute' not found in /home/domain/public_html/plugins/content/itpsocialbuttons.php on line 161
I guess you'll say that this is a 3rd party error, which does not much concern Kunena Discuss (but it might also have to do with the latter's implementation), but I was kind of alarmed by the fact that:
- although the topic appeared fine within the category (if I did not access the forms via the article link to the Kunena topic), whenever I tried to access it, I got the above page.
- Not only the topic's contents, but even the page for the poster's profile exhibits the same behaviour, with layout missing and character encoding messed up.
So data even outside the topic, and existing before it (the user's profile page) go wrong...consequently I am worried there might possibly be something which makes Kunena Discuss and maybe Kunena itself vulnerable...
htaccess: Exists | PHP environment: Max execution time: 30M seconds | Max execution memory: 64M | Max file upload: 5M
Joomla default template details : rt_versatility4_j15 | author: RocketTheme, LLC | version: 1.5.4 | creationdate: August 20, 2010
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Last edit: 15 years 8 months ago by etkritikonspoudon.
