Question complete article not copied to forum on replies
15 years 9 months ago #87012 by Acapulco Kevin
When I test reply on an article only the part under the "read more" inserted in the article is copied to the forum. It is also surrounded by a gray box.
I am using JCE editor and the latest versions of everything. i have included screen shots.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 8M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.0.5) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
15 years 9 months ago #87081 by Matias
Kunena discuss will not include article into the post -- it uses BBCode to get latest version of that article.
Bbcode has few options:
Article cannot be shown
15 years 9 months ago - 15 years 9 months ago #87095 by Acapulco Kevin
That is how it is set. When I click edit on the first post it shows the tags.
Example:
Last edit: 15 years 9 months ago by Acapulco Kevin.
15 years 9 months ago #87098 by Acapulco Kevin
If I put a read more at the bottom of an article nothing appears except a gray box in the forum.
If I put the read more at the very top of an article the entire article is copied to the forum but is still in the gray box.
Somehow... the forum is being told to ignore all text above the read more.
15 years 9 months ago #87127 by Acapulco Kevin
JCE Editor, TinyMCE, Kunena Forum and Kunena Discuss
Using JCE editor is very important to me and so are Kunena Forum and Kunena Discuss.
They must work together and I always seem to have issues.
When i insert the "read more" into an article the function takes you to the article page and you have the opportunity to leave a comment handled by Kunena Discuss.
The Article is supposed to be copied completely to Kunena Forum no matter what the content is. What happens is all information ABOVE the "read more" tag in the article is cut from the article and not included in the forum. It also leaves a gray box around the article portion that is copied to the forum.
Second issue... When JCE Editor is installed can I uninstall TinyMCE?
Thanks. I am looking forward to writing a positive review on JCE when this is working satisfactorily.
Posted on this forum and Kunena Forum.
15 years 8 months ago #88612 by Denny
watching this topic, same issues here
Time to create page: 0.155 seconds
