- Thank you received: 1
Sticky K 1.6 Discuss plugin is NOT backwards-compatible with old K1.5/K1.0/FB versions
Did you planned add backwards compatibility with old discussbot? Or maybe somehow update old one, to keep old style of working?
I can address these questionsRandal wrote: Did you planned add backwards compatibility with old discussbot? Or maybe somehow update old one, to keep old style of working?
I've often written about the origins of the old discussbot and the main problems with it. The "KunenaDiscuss plugin for Kunena" - that used to be listed in the Joomla Extensions Directory - was never an official part of the Kunena project; this software was developed by a user who was not associated with the project and who chose not to contribute to the development of software for K 1.6. The "KunenaDiscuss plugin for Kunena" - that people were, once upon a time, able to obtain from the JED - was, itself, modified from earlier software known as ObjectClarity Discussbot which only operated on J! 1.0 platforms. What this means, in effect, is that there hasn't been any discussbot software for K 1.5, maintained by anyone, for a very long time.
Because of the structural differences between K 1.5 and K 1.6, the old K 1.5 add-on will not work for K 1.6 and, vice versa, the plugin developed for K 1.6 will not work for K 1.5 and this goes for all Kunena add-ons. Basically, the Discuss plugin for K 1.6 is new software that was totally rewritten from scratch.
Because K 1.5 development has ceased there will be no retrofitting of K 1.6 features to that version.
I hope this explains the situation.
On the other hand: The fireboard/kunena discussbot or the ObjectClarity discussbot had a nice feature that I (and I think lots of other people too) miss so bad. If you write a new article for the frontpage you simply put a {mos_fb_discuss:9} at the end of the article. Then the users just click on the "discuss"-Button and the bot created a new post in the forum with topic taken from the article.
With the new kunena discuss plugin you have to create a forum post first and put a {kunena_discuss:#} into the article with the right ID from the previous created forumpost.
Maybe this can be added to one of the next versions of the plugin?
We need some way to assign imported data from old bot tables to new one.
Because articles that have already discussions now have ZERO replies.
I hope you understand me. And feature with link to article instead whole article in first post also wouldn't be hard to add in new version of bot.
The K 1.6 Discuss plugin is not backwards-compatible with old K1.5/K1.0/FB versions.
I need to qualify what might appear to be a an unsympathetic response. It's possible to make things "backwards-compatible" or, at least, to migrate existing Joomla articles to make them compatible with the new plugin but this takes time and at the expense of other, higher priority, needs. It should be entirely possible, for example, to migrate existing articles, where users have inserted those old {mos_fb_discuss:#) tags in their Joomla articles, into something else. It should also be possible to implement a way to mimic the behaviour of those old the Fireboard-style tags so that Joomla articles feed Kunena categories instead of, with the new approach, feeding Kunena topics.
If this is an urgent need, to provide the migration and functionality requirements of users, then the urgency can be resolved. The development team's main goal in releasing this new plugin was to meet the needs of the bulk of users who have relatively few Joomla articles on their websites; if users need to, they can change existing tags (where used) by hand relatively easily. Obviously, the more articles users have, the longer it takes to make the changes.
The needs discussed in this topic can be met in time. If users want to shorten the lead-time for this to happen, they can support the team in a financially-tangible way. In other words, if some users are prepared to pay the costs of making the necessary changes then the changes will be done sooner rather than later.
Randal's problems seem to be a little bit more urgent and complex. I think the best way would be to downgrade to kunena 1.5 until the problems have been solved and maybe someone has made a tool to migrate the old bot links to the new system.
The other way out seems to be a long weekend with editing all the articles and put new plugin links into them
