Question Using links to jump to forum and article again returns
- KunenaUserBeginnerLevel
1. Kunena Discuss uses links on both fronend (to jump to forum) and on the forum (to jump back to article). When I click on the link on the forum (to return to article commented), it shows an article with icons for edit, print, date created, and without main menu. All the buttons/options for the article are turned off in the article, and it has main meny assignment to it so, not sure why it returns like that from the forum.
2. I'm beginner to joomla too, forgive me about not knowing this, but how to enable comments only on specific article? (currently it's enabled on all of them)
I'm using joomla 2.5 and Kunena 1.7.2
Thank You
EDIT: I just found another bug: when kunenadiscuss opens up topic on the forum, it shows wrong "date created" for the topic (i.e. it wrote topic created 1y 2months ago although it was created moments ago).
(1) From the sounds of things, the problems you describe are not related to the Kunena Discuss plugin but are, more generally, caused by the way you have configured the Kunena component. I think you need to read the FAQs page (see the menu tab near the top of this page) and, especially, find out how to restore your Kunena menu properly.
(2) I'm not exactly sure I understand what you mean "how to enable comments only on specific article"? Do you mean, you want to disable comments on other articles? If that is what you mean, read msg #19 in Instructions for Kunena Discuss plugin
(3) I don't know about the wrong date created. Perhaps it would help to see your configuration report.
I'll try to explain a bit better: Kunena Discuss plugin creates a topic on the forum category which I connected to, right? OK, now, inside that topic, first post contains a LINK which returns back to the article where the comments took place. This link is created by the plugin, and when I click on it, it returns me to the page, but without main (joomla) menu, and with article options set to global (which means print/edit/send/date created/category/etc./ info is visible, and it shouldn't be). Now, I don't mind this link being turned off on the forum, so if there is way for this, this would already be a problem solver.(1) From the sounds of things, the problems you describe are not related to the Kunena Discuss plugin but are, more generally, caused by the way you have configured the Kunena component. I think you need to read the FAQs page (see the menu tab near the top of this page) and, especially, find out how to restore your Kunena menu properly.
OK, to make things clear, I have to insert {kunena_discuss:0} into every article on my site in order to disable comments from it?(2) I'm not exactly sure I understand what you mean "how to enable comments only on specific article"? Do you mean, you want to disable comments on other articles? If that is what you mean, read msg #19 in Instructions for Kunena Discuss plugin
I will gladly generate/send one, but how?(3) I don't know about the wrong date created. Perhaps it would help to see your configuration report.
Kunena menu details:Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 10 seconds | Max execution memory: 32M | Max file upload: 1500K
Joomla default template details : malita-fjt | author: FJT | version: 2.5.0 | creationdate: 28-02-2012
Kunena default template details : Darky Green 1.6 | author: gonzaunit | version: 1.6.0 | creationdate: 2010-10-25
board_offline 0 board_ofset 0.00 enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template daky-green-16 showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access joomla integration_login joomla integration_avatar auto integration_profile auto integration_private auto integration_activity auto boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc email_visible_address captcha_post_limit 0
(1a)
The easiest way for you to understand how things should work is to look at how they work here at this website. Go to the Discuss Articles category on this site and try things for yourself. How does this compare with what you've done on your site?KunenaUserBeginnerLevel wrote: [The] first post contains a LINK which returns back to the article where the comments took place.
(1b)
I don't know the answer to this question, and so I suggest you pursue your investigate along the lines I suggested in (1a) above.KunenaUserBeginnerLevel wrote: Now, I don't mind this link being turned off on the forum, so if there is way for this, this would already be a problem solver.
(2)
That's one way. It all depends which articles you want to discuss and which articles you don't want to discuss. You can enable or disable discussions for specific categories. For example, you may not want to discuss all categories. You could, for example, more specific articles into a "discuss-these-articles" category and enable the plugin only for that category. Or, you could "disable" discussions for specific articles using the method we've talked about. It all depends on how much (or how little) you want to use the Kunena Discuss plugin for.KunenaUserBeginnerLevel wrote: ... I have to insert {kunena_discuss:0} into every article on my site in order to disable comments from it?
(3) We cannot access your site. I don't know the answer to the "date" question. What is the creation date of these Joomla articles? Does the creation date of the article relate to the forum topic start date? I haven't performed sufficient tests myself to be able to answer you with how these dates may be related. Perhaps another member of the community can help us.
(4) Without being able to view your website, your configuration report shows that you do not have a Kunena menu present. Please read How do I restore my Kunena menu?
(5) Please also read Search Engine Optimisation (SEO) and implement the recommendations accordingly. This may assist you in the answer to Q1 above.
(6) Without being able to view your website, if you are unsure about how the changes you have made to your Kunena configuration may have impacted on its operation, I suggest you restore the configuration settings to their default values. There is a feature on your Forum Configuration page to do this.
