This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Question Connect already existing thread to article and Discuss?
14 years 8 months ago #117332 by LarsAgerstrand
I have a long ordinary thread in the forum.
I have now created an article about that matter and I would like to connect the thread to that article. So that the thread is connect as the default comment place for that article. Or else there will be two threads on the matter which is not good!
Is that possible?
14 years 8 months ago #117416 by Matias
Yes it is. Kunena Discuss actually has tooltips on how to do it (just go through the settings).
We have {kunenadiscuss:xxx} rule (check how it should be written), which can be used to assign any topic to the current article. Also make sure that discuss doesn't "close" the topic by allowing to post into infinity.
When you have make the binding between article and kunena discuss, you can safely remove above tag.
PS. tag can also be used to change topic to another.
14 years 4 months ago - 14 years 4 months ago #124262 by proterra
Matias wrote: Yes it is. Kunena Discuss actually has tooltips on how to do it (just go through the settings).
Didn´t know how it runs.
Have now an article, and merge the create thread with the existing, but that didn´t runs really.
The merge thread have the rule [ article ] 574 [ / article ]" 574 is the ID from the article. But if I´m only (without) merging fill out the code, nothing happens
My plan:
Have an new article and want it connect with a forum discussion.
Is it possible? And how it runs.
Last edit: 14 years 4 months ago by proterra.
14 years 4 months ago #125219 by proterra
Maybe someone can help?
14 years 4 months ago #125230 by Matias
Add {kunena_discuss:XXX} into your article where XXX is topic ID. Also remember to check if the feature is enabled.
If it works, you won't see above tag in your article. After getting the binding, you can remove the line.
The following user(s) said Thank You: proterra
14 years 2 months ago - 14 years 2 months ago #127731 by plunk
Struggling myself I found out:
When i go frontend to the forum, to the specific topic, the url looks like this:
/index.php?option=com_kunena&view=topic&catid=15&id=155&Itemid=25
id=155
{kunena_discuss:155} is the right syntax
My surprise was: 155, from Kunena category manager I would have expected 15 (see attachment 1).
I still don't understand! Why 155, where can I find that ID backend???
Last edit: 14 years 2 months ago by plunk.
