Idea [Gelöst] Install Problem SQL
English: Hello, i became error-messaging by installing Kunena by url:
* Komponente Installieren: DB function failed with error number 2006
MySQL server has gone away SQL=INSERT INTO jos_components VALUES( 0, 'Kunena Forum', 'option=com_kunena', 0, 0, 'option=com_kunena', 'Kunena Forum', 'com_kunena', 0, 'js/ThemeOffice/component.png', 0, '', 1 )
SQL =
* Error Loading ModulesMySQL server has gone away SQL=SELECT id, title, module, position, content, showtitle, control, params FROM jos_modules AS m LEFT JOIN jos_modules_menu AS mm ON mm.moduleid = m.id WHERE m.published = 1 AND m.access <= 2 AND m.client_id = 1 ORDER BY position, ordering
By/Bei /tmp/ Install
Warning: Could not load latest Version record.\nDB function failed with error number 1146
Table '*****.jos_fb_version' doesn't exist SQL=SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1;
SQL =
SELECT
`version`,
`versiondate`,
`installdate`,
`build`,
`versionname`
in /www/htdocs/*****/joomla2/components/com_kunena/lib/kunena.debug.php on line 52
Fatal error: Maximum execution time of 30 seconds exceeded in /www/htdocs/*****/joomla2/components/com_kunena/lib/kunena.debug.php on line 76
The installation brings an unfinished Kunena Forum!
German: CHMOD gesetzt#
Der Admin hatte mir zuvor gesagt ich sollte die Mysql version auf 5 updaten, das ist auch was ich getan habe. Nur scheint mir der gleiche Fehler wieder aufgetreten zu sein
English: CHMOD was set #
The admin told me to change my MYSQL Version up to 5; thats what i did. But There is the same Problem now i think.
SysInfo:
PHP version 5.2.4-2nmm2
Database: 5.0.51a-3ubuntu5.4
DB sort /sortierung: utf8_general_ci
We'll try to fix this for 1.0.8 (in most platforms). In the mean time you should increase timeout both for your php and MyQSL.
Do you know how to do this?
No, i can't, because of the pemissions-rights of my Provider. I will not longer wait for this! How i can fix it manuell?
I remember times without an installation process like in Joomla
Where i can follow the 1.08 dev Status?
- johnnydement
- Elite Member
- Thank you received: 5
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
The only option was to switch hosts as they would not admit to any problems on their end. If you are getting these errors possibly the same is happening to you. Large extensions, like forum components, take a lot longer to install. On some servers you may start running into problems like you are having. If you host is unwilling to help you I don't know what to tell you.
