Question Errors while installing.
15 years 4 months ago #99936 by md-jojo
I'm trying to install the latest version of Kunena Forum. I'm installing it on Joomla 1.6.3
I get the following error:
Failed loading XML file
/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/install.xml
XML: failed to load external entity "/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/install.xml"
/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/j16upgrade.xml
XML: failed to load external entity "/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/j16upgrade.xml"
/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/kunena.install.upgrade.xml
XML: failed to load external entity "/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/kunena.install.upgrade.xml"
/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/kunena_upgrade.xml
XML: failed to load external entity "/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/install/kunena_upgrade.xml"
/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/kunena.j16.xml
XML: failed to load external entity "/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/kunena.j16.xml"
/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/kunena.xml
XML: failed to load external entity "/web/www/joomla-1.6.3/joomla/tmp/install_4e118c7e82452/kunena.xml"
JInstaller: :Install: Cannot find Joomla XML setup file
What am I doing wrong :dry: ?
15 years 4 months ago #99937 by md-jojo
I've done abit of searching and thought the problem mught have been the memory limit set on the server so I have installed via a directory and I get a different error:
Warning: simplexml_load_file(/web/www/joomla-1.6.3/joomla/administrator/components/com_kunena/install/install.xml): failed to open stream: Permission denied in /web/www/joomla-1.6.3/joomla/libraries/joomla/factory.php on line 350 Warning: simplexml_load_file(/web/www/joomla-1.6.3/joomla/administrator/components/com_kunena/install/j16upgrade.xml): failed to open stream: Permission denied in /web/www/joomla-1.6.3/joomla/libraries/joomla/factory.php on line 350 Warning: simplexml_load_file(/web/www/joomla-1.6.3/joomla/administrator/components/com_kunena/install/kunena.install.upgrade.xml): failed to open stream: Permission denied in /web/www/joomla-1.6.3/joomla/libraries/joomla/factory.php on line 350 Warning: simplexml_load_file(/web/www/joomla-1.6.3/joomla/administrator/components/com_kunena/install/kunena_upgrade.xml): failed to open stream: Permission denied in /web/www/joomla-1.6.3/joomla/libraries/joomla/factory.php on line 350 Warning: require_once(/web/www/joomla-1.6.3/joomla/administrator/components/com_kunena/install/model.php): failed to open stream: Permission denied in /web/www/joomla-1.6.3/joomla/tmp/com_kunena_v1.6.4_b4832_2011-05-07/install.script.php on line 22 Fatal error: require_once(): Failed opening required '/web/www/joomla-1.6.3/joomla/administrator/components/com_kunena/install/model.php' (include_path='.:/usr/share/php:/usr/share/pear') in /web/www/joomla-1.6.3/joomla/tmp/com_kunena_v1.6.4_b4832_2011-05-07/install.script.php on line 22
15 years 4 months ago #99949 by md-jojo
Hi All,
Seems it was a problem with permissions.
All sorted now :cheer:
Time to create page: 0.098 seconds
