Question Kunena Installed already error
15 years 5 months ago - 15 years 5 months ago #98062 by Johnsixfox
File Attachment:
File Name: No_3_Problem.doc
File Size:168.5 KB
File Attachment:
File Name: No_1_snapshot.doc
File Size:182 KB
BIG problem.
OKay, this is the history:
I have installed Kunena forum already, but there was a errors, i have tried my best to fix it, ut i can't.
I have created a Kunena main menu, when I tried to select any item that are consisted of kunena e.g: entry page, profile and etc, I end up getting errors.
check the attachements:at no1 snapshot, i click on entry page and the result is at no_3_problem
I hope someone will understand my problem.
Last edit: 15 years 5 months ago by Johnsixfox.
15 years 5 months ago #98092 by sozzled
You have some basic problems with J! 1.6. What version of J! 1.6 are you using?
15 years 5 months ago #98102 by Johnsixfox
I'm using jt004_j16 template
see also
joomlathemes.co/1-6-templates/40-software
thanks you
15 years 5 months ago #98106 by Johnsixfox
Johnsixfox wrote:
File Attachment:
File Size:168.5 KB
File Attachment:
File Size:182 KB
BIG problem.
The Problem above is now seem to be solved and everything else is working fine unless the ARTICLES problem that we are currently discussing on my other post
thanks you
