Question upgrade problem from 1.6.3 to 1.6.4
14 years 11 months ago - 14 years 11 months ago #96506 by xillibit
I'am not sure that english languages files has been copied during kunena installation, so you can check if there are english files for Kunena in language directories and switch to english.
Or you can directly download the italian languages files form here :
joomlacode.org/gf/project/kunena/scmsvn/...Flanguage%2Fit-IT%2F
and updates them.
Last edit: 14 years 11 months ago by xillibit.
14 years 11 months ago #96515 by 810
1) Extensions » Language Manager and make English the default language
2) delete kunenamenu
3) install kunena
regards 810
14 years 11 months ago #96569 by RoB ReZNoR
810 wrote: 1) Extensions » Language Manager and make English the default language
3) install kunena
regards 810
i've tried to do that, and the issue is the same.
14 years 11 months ago #96605 by RoB ReZNoR
i've solved the issue
i will release the italian version of kunena 1.6.4 as soon as possible.
thanks to all..
Time to create page: 0.333 seconds
