Question Login and logout problem
15 years 6 months ago #95290 by jose
I there
I upgraded to K 1.6.4 from 1.5.11 and problem is users login but it not refresh info. They have to reload page and then they can see it. Sometimes it shows "Invalid token".
Problems are with firefox 4. With Chrome there are problems but less.
It seems that is a problem with cache. I disabled all joomla cache in Global configuration and cache plugin but problem persists.
Maybe problem is due to I did some data migration to test but I always truncate MySQL tables. Until this one I had not problems, but this is the production site!!
Yo can see at 50.22.107.92/~bosqueth/index.php?option=com_kunena
I have ACESEF. This URL is without it because maybe I will change some AceSEF urls
Any idea? Thanks
15 years 6 months ago #95298 by sozzled
I can't see anything at the URL you posted. "Invalid token" is not a Kunena issue; it's a Joomla issue.
You might help us to help you better if you posted your K 1.6 configuration report.
15 years 6 months ago #95320 by Matias
Replied by Matias on topic Re: Login and logout problem
Invalid token error comes in this case from Joomla, and I must say that I totally agree on you -- it's very annoying. I believe that they have changed it into nice looking warning message "your session has expired, please try again" in J1.6.
The error comes when users session times out and token in the login form gets old. Token is used to prevent attacks, where you can take over users session. But the implementation in this case is very bad..
There is an easy solution how to prevent these issues and it's to reload the page just before filling up login information. Yeah, I know.. It's just something you need to teach to your users. I have plans to change the login to be directed via Kunena 2.0 which would solve the issue.
15 years 6 months ago #95332 by jose
Replied by jose on topic Re: Login and logout problem
Hi sozzled
URL is bosquetheravada.org/foro-dp74
This is the configuration report. Thanks
Joomla default template details : ja_lime | author: JoomlArt.com | version: 1.0.1 | creationdate: 03/02/2010
Third-party components: AlphaUserPoints 1.5.13 | UddeIm 2.3
Third-party SEF components: AceSEF 1.5.16
Modules: Kunena Latest 1.6.4
15 years 6 months ago - 15 years 6 months ago #95457 by jose
I reinstalled K 1.6.4 and now everything it´s OK.
Thank you for your support
Last edit: 15 years 6 months ago by jose.
