- Thank you received: 566
Important [Solved] Upgrading from 1.6.0 to 1.6.4 error!
There are many template parameters in default template, so you may find these from the template.
If it doesn't work, you can always use FireBug (or similar) tool to find the CSS rules.
I've attached in the post above the file, but anyway, I've sent it to the e-mail you've requested.
Regarding the FireBug, it isn't showing the css file name where it is as you can check this thread:
www.kunena.org/forum/170-k-16-templates-...164-css-issues#95582
FireBug always shows file and line.
Matias wrote: Language files are impossible to find from the forum, so the only reliable way to get them into the release is to send email.
What I meant regarding the language files was that I had attached it two posts above as zip file. ;0)
Regarding Fire Bug, it shows the line number, but not the file name these lines are, it is showing the link instead as it:
www.esferadobem.com.br/index.php?option=...nc=latest&Itemid=112
Let's get back to the basics. What happens if you you the installation/upgrade method described in K 1.6 Upgrade Guide ? Have we fixed the "errors" you got at the start of this topic ... or are we off on some new topic?
sozzled wrote: iLucato: You have two topics running simultaneously. One topic concerns the upgrade (and it has something to do with the language files). The other topic has something to do with CSS changes. Please try to keep the topics separate.
Hi Sozzled, yup, one subject brought another and it ended up running into two subjects. I'm sorry about that. Regarding the main topic here, it was solved as I've edited the tittle and posted that:
"...Yup, I had all as 755, but there is something they changed in the server that I'm not getting to move, delete and so on. Sometimes creting folders create as "nobody" or 99 99. But I got a solution to install Kunena. just to share if somebody is facing the same issue. I've changed all Joomla folders to 777 (Checked from Joomla help/system info/directories) and set also the FTP into Joomla into global settings / system."
as you can read in this thread.
I'll try to keep the topics separated. ;0)
