Question [solved] Problems upgrading from K 1.5.14 to 1.6.3
nginx proxy with freebsd jailed apache
solved: moving to another host
If you didn't do that then you do not have the same problem. Please do not try to "piggy-back" on someone else's topic by saying I have the same problem ... when you don't.
Please read K 1.6 Upgrade Guide and, if that doesn't answer your questions, please start a new discussion topic and include all the relevant details about your specific problems. Thank you.
sorry ...yes i didnt do exaclty the same steps above...
but the problem looks the same to me a blank page - when i tried to upgrade. I also tried to debug, check logs, disable modules, plugins.
When i got that blank page i went back to my components - select Kunena and then im getting to the same page as Yxos gettin, with "prepare installation OK" and when i pressed next - bam a blank page again.
after that i installed 1.5.14 but when i tried to read any post still this annoying blank page.
Until yesterday i had everything working, but in one moment all my users post inside the forum were pointing to a blank page - thats why i try upgrading(it is not the first time when this is happening, last time i used backup to fix it, month ago, now i have to do it again)
could it be because my Joomla template(old one) is not compatable with the mootools for kunena 1.6?
i made a fast read of the upgrade instructions i hope i didnt miss anything, im just wondering why is this happening... and i dont want to "piggy-back", if i really did it, im sorry.
but after nothing worked i searched and this is the only thread that was close enough to my problem.
So i will just watch you guys resolving this issue and im hopping it will help me resolving mine too. thanks
Upgrading from K 1.5.x to K 1.6.x presents its own unique difficulties. Most of these problems are not due to Kunena itself but are due to a combination of other software that may be running. For example, some people upgrade to K 1.6.3 but leave behind some old K 1.5 modules and this causes blank pages nearly every time. Then there are cases where people are using incompatible versions of "integrated" components (like JomSocial, Community Builder, uddeIM, and the like) and these, too, yield blank pages.
Please read very carefully K 1.6 Upgrade Guide .
Although it usually only takes a couple of minutes to upgrade from K 1.5.14 to K 1.6.3 if you don't do the necessary groundwork first the results may not always be pleasant ones. Mootools incompatibility is a major headache because people are using old, outdated and "clunky" software that was developed by people long before Joomla settled on Mootools 1.2.4 as the "standard".
Yes, it's possible that your site template is the culprit (but it's unusual to see blank pages as the result). If you have upgraded to K 1.6.3 on your site, we might be able to give you a few tips on what you can look for if you can post your K 1.6 configuration report.
update was smooth!
