Question 500 - Kunena function "forum" not found
15 years 8 months ago #88456 by trusco1973
Hi, after upgrading, I got a problem with facebook URLs.
I got the problem in object with all forum links.
I wondering it was a joomSef problem but I try to add url/alias to solve without solving.
Have you got any idea?ù
thanks
Trusco
15 years 8 months ago - 15 years 8 months ago #88458 by sozzled
G'day, trusco1973, and welcome to Kunena.
I'm sorry, since when were Facebook URL problems part of Joomla ... or Kunena? I have no idea what you are talking about.
To diagnose HTTP 500 server error problems you need to turn on Joomla debug mode. HTTP 500 server errors usually indicates that you've got software errors. Usually, when people ask us about HTTP 500 server errors, these things have nothing to do with Kunena. You've probably got a defective Joomla extension running on the same page as Kunena.
15 years 8 months ago #88460 by trusco1973
Hi sozzled and thanks for your quicky answer.
My site has a feed publishde on facebook. That feeds are generated from Kunena Forum and other categories. That problem is just born after upgrading Kunena forum from 1.5.11 to 1.6.3.
And only forum links are broken, other ones are still working.
I'll try to enable debug mode to go deeply ...
Trusco
15 years 8 months ago - 15 years 8 months ago #88468 by sozzled
Let's deal with one problem at a time. The main problem is the 500 errors. Joomla debug will tell you what is being loaded on your pages and what is the likely cause of the errors. I'm not an expert in these things but I'm sure one of the other members of the team can give you some better pointers. :)
15 years 8 months ago #88649 by Matias
For some reason it looks like your URLs have been changed from K1.5 to K1.6. Above error means that your URLs look like this to Kunena: /forum/forum/...
I do believe that it's SEF issue (messing up old URLs), but without a link to your forum it's impossible to know.
I do know that Joomla SEF URLs haven't not changed from K1.5 to K1.6.. I would ask support from JoomSef author.
15 years 8 months ago #88694 by trusco1973
Hi, true.
I noted that the addess has changed.
I really don't know if it was a SEF issue, I didn't change manually.
Changing menu title voice, everything goes right.
Thank for your help.
Trusco
