Question Problem with 162 and 163
15 years 8 months ago #88336 by rotor
I've tried to upgrade both 162 and 163 over the top of 160 betta 1 using Joomlas Extension manager and I cannot. It tells me - "There was an error uploading this file to the server."
If I delete the tables and both Component Directories it will only allow me to install the 160 betta 1 and not 162 or 163 - same error "There was an error uploading this file to the server."
15 years 8 months ago - 15 years 8 months ago #88337 by sozzled
G'day, rotor, and welcome to Kunena.
Have you tried upgrading (installing) using the URL method? Does your website meet the technical requirements ?
15 years 8 months ago - 15 years 8 months ago #88338 by rotor
Replied by rotor on topic Re: Problem with 162 and 163
By that u mean uploading to the install component directory in admin??
Been that long since I've had to install anything in there that Ive forgotten whether to upload the .zip file or open it and upload the entire contents as it extracted .... :S
Last edit: 15 years 8 months ago by rotor.
15 years 8 months ago #88342 by sozzled
I mean install by the URL method. The method is explained in K 1.6 Installation Guide .
The following user(s) said Thank You: rotor
15 years 8 months ago #88345 by rotor
Ah!
Ok, that took all of 20 seconds and worked great!!
Thx ... sozzled!!
