Question Kunena 1.6.3 installation problems
15 years 2 months ago #86537 by jancic
Hi everybody,
at the moment I am rebuilding my web page and by that I mean also installing a new forum. I tried to install Kunena forum 1.6.3, yet I can not.
I attached a print screen.
What can I do?
15 years 2 months ago #86542 by xillibit
Read this : docs.kunena.org/index.php/K_1.6_Installation_Guide
Why the previous install has failed ? Can-you give please most details on this ?
15 years 2 months ago #86544 by jancic
This problem apperas when I try to load the package...
15 years 2 months ago - 15 years 2 months ago #86550 by sozzled
jancic wrote: I am ... installing a new forum. I tried to install Kunena forum 1.6.3
This is what I would do.
(1) I would try to uninistall the Kunena component using the Joomla Extension Manager.
(2) I would use phpMyAdmin and DROP all tables in my database with the prefix jos_kunena*
(3) I would follow the all of the instructions K 1.6 Installation Guide very carefully!
Last edit: 15 years 2 months ago by sozzled.
15 years 2 months ago #86707 by Matias
(2) PHPMyAdmin DROP can be replaced by choosing Remove Kunena 1.6
15 years 2 months ago #86769 by jancic
I tried both options, reinstalling Kunena and removing Kunena, both end up with the same result:
Remote server or file not found
I will try to manually drop all the tables with the prefix jos_kunena*, just like sozzled suggested.
Time to create page: 0.247 seconds
