- Thank you received: 3
Idea Failed during migration Fireboard with missing Factory Class [solved]
i get this Error Message when i try to install 1.6.3 and to migrate the fireboard 1.0.4 Stable
The first steps migrating the data is all set to ok with green.
When it goes to the Next Step it breaks with
Fatal error: Class 'KunenaFactory' not found in /www/htdocs/w00cd59d/sites/..../home/administrator/components/com_kunena/install/upgrade/upgrade-1.6.0_configuration.php on line 17
Please help!!
it's not clean i know but it did the work.
Interesting though is to know where the problem comes from. i have no clue. You?
I solved it copying the factory class in the upgrade-1.6.0_configuration.php" I don't know what that means.
Any ideas?
replace your upgrade-1.6.0_configuration.php with the one attached and the install procedure will continue and work fine.
