Question Fatal error: Call to undefined method JFactory::getTemplate()
15 years 10 months ago - 15 years 10 months ago #82391 by Inlinerbutch
Hi fellows,
I am running a site with Joomla 1.5.22 and Kunena 1.6.1 and everything is fine.
Now I made a clear, fresh Joomla 1.6 installation with Kunena 1.6.2. It's a fresh installation and only the sample data from Joomla are in to test the new version.
The installation of Kunena 1.6.2 was easy and fast.
I have two problems :
  • I have no tabs on the starting page of Kunena
  • I got no Kunena menu
To find the problem I started the "Report Configuration Settings" and got the message below:
Fatal error: Call to undefined method JFactory::getTemplate() in /opt/lampp/htdocs/joomla16/administrator/components/com_kunena/admin.kunena.php on line 3053
Is this a bug or a known issue I can solve with a work arround?
Regards
Uwe
Last edit: 15 years 10 months ago by Inlinerbutch.
15 years 10 months ago #82392 by etusha
K1.6.2 is NOT compatible with J1.6(have some know issue and they fixed )
Wait for K1.6.3 if you like you can join to Tester Team have a dev build and report issue
for more information contact @matias
The following user(s) said Thank You: Inlinerbutch
15 years 10 months ago #82394 by Inlinerbutch
Hi etusha,
thanks for the information. I send a message to matias.
Kind Regards
Uwe
15 years 10 months ago #82437 by xillibit
You need just to join the tester group : www.kunena.org/people/groups/viewgroup/1...icial+Kunena+Testers
15 years 10 months ago #82799 by Inlinerbutch
Hello xillibit,
thanks for the hint. :)
Regards
Uwe
