Question Upgrade 1.6.0 to 1.6.2
15 years 3 months ago - 15 years 3 months ago #81559 by MJW
Upgrade 1.6.0 to 1.6.2 was created by MJW
Hello, I am getting this error when I try to upgrade to 1.6.2 "There was an error uploading this file to the server." "Unable to find install package" I have Joomla 1.5.22. I have read the other posts on this subject and think perhaps there is a limit to the size of file I can upload but I'm afraid I don't know where to look to find or change the limit.
I would much appreciate your advice please. Thank you.
Last edit: 15 years 3 months ago by MJW.
15 years 3 months ago #81576 by xillibit
Replied by xillibit on topic Re: Upgrade 1.6.0 to 1.6.2
This doc should help : docs.kunena.org/index.php/Installation_Issues
15 years 3 months ago #81584 by MJW
Replied by MJW on topic Re: Upgrade 1.6.0 to 1.6.2
Thank you for your reply. I have found the php settings and they are OK so I tried again but still get the same message "There was an error uploading this file to the server." "Unable to find install package" . I am really sorry to ask but I am a virtual novice and I am not sure where to unpack the files. Have I understood correctly that I need to unzip the Kunena download and send it via ftp to a new directory which I should name Kunena temp. Then when I have done that I go to the back end install manager and have a go at installing from that temp directory?
15 years 3 months ago #81661 by sozzled
MJW wrote: Have I understood correctly that I need to unzip the Kunena download and send it via ftp to a new directory which I should name Kunena temp. Then when I have done that I go to the back end install manager and have a go at installing from that temp directory?
This is not normally how you would install other Joomla extensions.
Do you know how to install Joomla extensions? Joomla provides three ways for you to install Joomla extensions:
(1) You can copy the installation kit from this website to your PC and then use the first option to upload the .ZIP file to your website and the installation process will continue from that point.
(2) You can copy the installation kit to your temporary directory and you can install it from there (whether you use the compressed or uncompressed version).
(3) You can install Kunena by pointing your website to the URL of this website where the installation kit is located.
The following user(s) said Thank You: webwannabee
15 years 3 months ago #81741 by MJW
Hello Sozzled, Thank you very much indeed for your reply. I'm really sorry to be such a dummy but I am still have problems. I cannot install this component via the first method, which is the one I normally use. After reading you helpful reply I have tried method 2.
I uploaded the file via ftp to my public html tmp file then I put this path into the install from directory option via this path "/home/ariegeau/public_html/tmp/comp_kunena_v1.6.2._b3894_2010-12-20.zip" and I got this message "Please enter a package directory".
I also tried "install from URL" by imputting www.kunena.org/download/comp_kunena_v1.6...b3894_2010-12-20.zip
and I got these messages
* JFolder::files: Path does not point to a valid folder or the folder has been deleted.
* JFolder::folder: Path does not point to a valid folder or the folder has been deleted.
* Error! Could not find a Joomla! XML setup file in the package.
Notice: Array to string conversion in /home/ariegeau/public_html/libraries/joomla/installer/helper.php on line 64
Warning: array_merge() [function.array-merge]: Argument #1 is not an array in /home/ariegeau/public_html/libraries/joomla/installer/helper.php on line 142
Warning: array_merge() [function.array-merge]: Argument #2 is not an array in /home/ariegeau/public_html/libraries/joomla/installer/helper.php on line 142
Warning: Invalid argument supplied for foreach() in /home/ariegeau/public_html/libraries/joomla/installer/helper.php on line 187
I realise I must be doing something stupidly wrong and I really would appreciate your further advice please.
15 years 3 months ago - 15 years 3 months ago #81780 by sozzled
Replied by sozzled on topic Re: Upgrade 1.6.0 to 1.6.2
MJW wrote: I really would appreciate your further advice please.
This is the installation method, from help.joomla.org/content/view/1476/278/ with a few modifications:
  • Upload Package File: Use the following steps to browse to the location where you downloaded the Kunena package file then press "Upload File & Install". Joomla! will read the contents of the archive file and install Kunena.
  1. 1. Download the archive file (normally ".zip" format) from Download area to a local directory on your computer. We sometimes call this the Kunena "installation kit".
  2. 2. Use the "Browse" button in the "Upload Package File" to browse to the archive file.
  3. 3. Use the "Upload Package File" button to install the Extension. Joomla! then unpacks the archive file and installs Kunena.
  • Install from Directory: As an alternative to installing from an archive file, you can follow the steps below:
    1. 1. Create a temporary directory on your local hard drive and unpack Kunena installation kit in this temporary directory.
    2. 2. Using FTP, upload the contents of this directory (including files and subdirectories) to a directory on your server.
    3. 3. In the Install Directory field specify the directory where you have uploaded the files and subdirectories of the package.
    4. 4. Click on the Install button and Joomla! will install the contents of the given directory.
  • Install from URL: A third alternative for installing Kunena is as follows. Instead of downloading the archive file to your local computer, just specify the URL of the target archive file. Then click the "Install" button and Joomla! automatically installs it directly from this URL. Note that, with this method, you will not have a copy of the archive file on your local computer.
    • For our purposes, the URL of the installation kit file is
      http://joomlacode.org/gf/download/frsrelease/13390/59237/com_kunena_v1.6.2_b3894_2010-12-29.zip
    • For many people, this is actually the preferred method of installing Kunena.
    To upgrade Kunena from an earlier version, follow the same installation procedure above. This will then run the Kunena installer program on your website that will complete the upgrade process.
    Last edit: 15 years 3 months ago by sozzled.
