Question Catchable fatal error
16 years 3 weeks ago #68361 by bigmike0601
Joomla 1.5.21
Kunena 1.6
www.marguglio.com
Installed K1.6 and links show this fatal error:
Catchable fatal error: Object of class CKunenaConfig could not be converted to string in /home/margugli/public_html/administrator/components/com_kunena/libraries/user.php on line 69
16 years 3 weeks ago #68364 by xillibit
Replied by xillibit on topic Catchable fatal error
You are using old and obsolete modules, please uninstall completly to using kunena 1.6.0
16 years 3 weeks ago #68373 by bigmike0601
Replied by bigmike0601 on topic Catchable fatal error
How do I know which modules to uninstall? Are there new upgraded modules for the ones I need to uninstall? I know these are basic fundamental questions and I do appreciate your help.
Mike
16 years 3 weeks ago #68375 by xillibit
Post your kunena report configuration settings here : www.kunena.com/forum/168-k-16-support/56...-when-asking-support , i will tell you what do you need uninstall.
16 years 3 weeks ago #68379 by bigmike0601
xillibit wrote: Post your kunena report configuration settings here : www.kunena.com/forum/168-k-16-support/56...-when-asking-support , i will tell you what do you need uninstall.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 15M
Modules: Kunena Latest: Enabled (Version : 1.0.47) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
16 years 3 weeks ago #68381 by xillibit
It seems that you have just the old version of module latest post, please unisntall it.
You will find here, new versions of modules to work specifily on kunena 1.6.0 : joomlacode.org/gf/project/kunena/frs/
